Results 1 to 1 of 1
Thread: Ultimate charger 10v to 100v all chemistry
    Jul 2016
    30
    Features
    The Battery Charger has been designed to provide reliable, quality charging for battery systems in
    electric drive vehicles. It is a high efficiency wide input voltage charger, the charger can output 1500W at
    AC90V~265V in a smaller size. Many creative technology help to realize up to 94% of efficiency, and the
    internal temperature is still under 50℃. The following are some new features:
     Intelligent control output voltage and current by microprocessor, 100% calibration before
    delivery
     1% voltage and current accuracy
     Active PFC: smaller AC input current less interference, and Conform to European Commission
    Regulation no 278/2009 and Energy Star Version 2.0
     AC 90-265V worldwide operation: need not any alternative switcher, worldwide safe operation.
     Low power consumption (less than 1W) at idle mode and standby mode
     Up to 94% of convert efficiency.
     Programmable output voltage from 10V to 102V
     Programmable output current from 1A to 25A
     TFT color LCD display output Voltage, current, power and internal temperature on time.
     Over current, over voltage, over load, over temperature, and short circuit protection
     Short-circuit protection on output, safer and more reliable.
     2 Intelligent cooling fans turned on and adjust speed upon the temperature automatically
     ZVS/ZCS and Synchronous Rectification
    assure the highest efficiency.
     High power density: 652W/Kg
     Start at no load or full load
     Approved by CE
     24 months warranty
    Application
     Home application
     Electric drive vehicles
    MSRP $350
