Results 1 to 4 of 4
Thread: Does Sevcon Gen 4 size 6 need a heatsink?
    Oct 2016
    Salt Lake
    49
    Hi all,
    I'm moving from my Kelly 8080 to a Sevcon Gen 4 Size 6.
    Anyone running one without an additional heat sink?
    I know it shouldn't burn out but I would like to avoid current limiting on the highway if possible.
    I'm running 96v On a ME0913.
    Thanks.
    2,647
    Yes it does. Or just something big and metal that can dissipate the heat.
    Moderator Nuts & Volts's Avatar
    Columbus, OH
    1,792
    On my 375lb R6 I ran without a heatsink. Average power was like 7kW, but I did pull peaks of 64kW too. I did have it attached to a ¼”thick piece of Alum. No thermal paste. Controller was on the bottom of the bike and exposed to direct airflow thou.
    Very possible to run without one, but the system must be properly designed for it.
    Sent from my iPhone using Tapatalk
    Whats under my tank may shock you!!! R6 Build, Blog/, [/URL] OSU Current webpage
    750
    Quote Originally Posted by Nuts & Volts View Post
    I made a water cooled one ...not the prettiest but it passed a 8 psi leakdown test. Now that I made one I know my next attempt will be better
    Sent from my Pixel 2 using Tapatalk
    Attached Images Attached Images
    Current builds: WORX.VOR.v3.2
