Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: 1985 Vespa PX-150 Conversion
    Junior Member Headway-Headquarters's Avatar
    Jan 2011
    Mineral, WA
    25
    Hey all!
    Been lurking around here on the forums for quite awhile now, the whole 'long time listener first time caller' thing! I have to say thank-you to the many who have provided me some great knowledge and understanding with their postings, so again I say, THANK-YOU!
    Been working on my first street legal EV conversion for about 6 months now (when I have the time) which will be for putt-sing around town, an '85 Vespa PX150 scooter. Was actually inspired by Soyachips project, and have always wanted a Vespa to goof-off with but hated the whole 2-stroke sound, smoke and all the mess of the oil and mix. Anyways, I picked it up last year off of Craig's List and here I go with posting what I have been doing with it!
    I chose to go with a hub motor since it didn't seem like anyone had tried that yet (that I could find anyway), using the old gas and oil reservoirs under the seat for the components ie, Kelly controller, contactor, etc. and under the side cowls on both sides to carry the battery pack to help with balancing out the scooter. I determined I can fit a 72V (76.8V) 30Ah battery pack using this layout, but it has caused a few head scratching sessions!
    Probably didn't get the best of components, but for my needs and budget, hopefully they will work out for the time being until I need to change them out!
    Jan 2011
    Mineral, WA
    25
    Having the initial plan and layout of how I thought I could easily just take stuff apart and put it back together and 'presto change-o an EV Vespa', I started stripping the scooter down.
    Went even farther and started sanding out the rust and decided to just redo the whole thing!
    Did a little body work and went back to my surfing roots and decided to resin and fiberglass patch the old choke and fuel shut-off and figured it would be a good place for the emergency shut-off button.
    Next was to fab a new swing arm for the hub motor and hoped that all would work out with the rear shock (Head-scratcher #1!) but thankfully my measurements were good to go!
    687
    nice work on the swing arm...looks like vespa pulled it from stock and shipped it to you!
    Jan 2011
    Mineral, WA
    25
    While the scooter was at the paint shop, I started working at changing out the the front drum brakes to disc brakes
    This was another head-scratcher for me since I blindly just purchased the front disc brake thinking it would work for the scooter since it was 'listed to work' but not knowing that my suspension link was 20mm dia and the brake system I purchased was for a 16mm dia suspension link.....DOH! But got it sorted out and moved on!
    Refinished the steering column, front suspension link, etc. and installed the disc brakes and front shock. (When funds permit, will change out to hydraulic front brake....maybe!)
    Purchased a nice new 'hi-tech' speedo with a tach.....ooooooo....ahhhhhh (am wanting to work at changing it over to an ammeter) just to have a little more modern look for the gauges.
    Got all the parts back from the paint shop.
    Member 1320freek's Avatar
    Nov 2011
    Titusville, Fl
    84
    That thing looks pretty awesome!! Nice work. Can't wait to see the finished product.
    Moderator ZoomSmith's Avatar
    Walla Walla, WA
    775
    I've never gotten the whole scooter thing, but that is some nice fab work.
    Jan 2011
    Mineral, WA
    25
    Thanks all, wish I could take credit for those welds, but I can't! Thankfully I met some folks who are fabricators that do awesome work!
    Got the tires mounted to the hub motor, went with black paint and thought I gotta go with a classic, the white-wall!
    The speedo was designed more for the smaller framed Vespa scooters....
    So worked with my neighbor who built a homemade CNC machine and made an aluminum escutcheon to help with the problem.
    Next head-scratcher was to change out the handle bars from the Vespa standard of 24.5mm dia to a more universal 7/8" or 22mm dia handle bars for the throttle and left grip. The head piece was cast for the larger size.....
    ....so needed to cut-off what was need to work with the head piece then attach some 7/8" chromoly for the remainder of the handle bars
    Jan 2011
    Mineral, WA
    25
    The new handle bars are in place
    Tapped a set-screw to keep the handle bars from twisting in the head piece
    The 78" handle bars were sleeved with the 24.5mm handle bars before they were welded together
    Test mounting the components and using a glove box light switch button to control the LED's so I have some light when I need to check under the hood...errrr I mean seat!
    Not much room for a DCDC converter and not much room for an auxiliary 12V battery, but found a nice spot under the rear part of the seat.
    Jan 2011
    Mineral, WA
    25
    Changing out as many lights as possible to LED's
    Got the front fender and and suspension put back on
    Checking the buss bars and double/triple checking battery sizes
    That is about where I am at for now!
    Currently working on the new wire harness since the original was just an oily mess and just starting to put things back together!
  10. Likes ashoxy liked this post
    Detroit, MI.
    276
    Welcome! Great looking work so so far! What kind of batteries did ya select?
