Results 1 to 10 of 19
Thread: SuperScoot!
    SuperScoot!
    OK, time to go legit with this caper. I just picked this up:
    It's got a cooked brushless hub motor, and though I've taken them apart in the past, it's a frustrating exercise in futility. Even after replacing the controller and Hall sensors, my last project never worked. I've got two options, as I see it. Replace the hub motor (with a BIGGER one) or bolt in one of the ETEK motors I happen to have laying around. Which, right now, is what I'm leaning towards doing. Replacement wheels are up on the eBay for less than $50, and the idea of having a 10kw motor in there instead of some 800W hub just makes me start giggling.
    I've got a little pile of Headways that will replace the lead...
    Let the Madness Begin!
  2. Likes Hugues liked this post
    Senior Member Athlon's Avatar
    Jul 2011
    Milan, Italy
    Add Athlon on Linkedin
    As motor I see much better an hub motor like the Enertrak ( 10Kw cont -30Kw peak) so you don't have to mess with chain or belt
    2,880
    Good luck Ted. I like that scooter. It should keep you busy for a while.
    BMW seems to think scooters, including electric versions, are a wave of the future according to this speculative article: http://www.autoblog.com/2012/08/27/b...oter-business/
    Well, the Enertrak is pretty big, pretty heavy, and I'm not sure Mark can mount them on a 10" wheel. Plus, they're over $1k. (My ETEK is sitting on a shelf, looking at me forlornly, wanting a purpose in life. AKA no cost.) Any of the smaller hub motors top out at maybe 1.5kw. Plus I like the option to play with gearing, which you can't do with a hub.
    So... uh, yeah. Complete wheel assemblies from Monster Scooter for around $50? SOLD!
    http://www.monsterscooterparts.com/rearwheels.html
    With disk brake and sprocket: http://www.monsterscooterparts.com/cu12x3rewhas.html
    110
    There is a guy on E-S that is selling a 2 speed hubmotor for a 10" wheel. He runs it over 60 MPH on hills in Costa Rica, and, I have one sitting in customs right now, in CR. They are pretty small for what they are. Nice big axle, also, and drum brake.
    1,086
    I like this retro style a lot for scooters, the new one from BMW looks too "electric", futuristic wannabe.
    Just my opinion.
    869
    Harold,
    "There is a guy on E-S that is selling a 2 speed hubmotor for a 10" wheel. He runs it over 60 MPH on hills in Costa Rica"
    http://www.youtube.com/watch?v=iU6Z5GG0D4c&feature=plcp
    I love John's bike. But that performance is in a 100 pound "bicycle." In a several hundred pound scooter, it wouldn't be quite as impressive. On the other hand, I think John weighs about 100 pounds more than Ted.
    Warren
    110
    Warren, you could be correct. I think the 2 speed will make a world of difference in getting going. He has NO pedals on his homemade frame, and, does weigh over 260 pounds.
    It's just for Ted to see the info, and know these are tested to be what he says, before selling them.
    "Several hundred pound scooter"? If the thing is over a hundred, I'll be bummed. Running the ETEK at 48V should have plenty of pep for that little thang, though the idea of a smaller two speed hub motor does sound interesting. Think maybe I should name this project the "What I have Lying Around Prjoect", maybe that would explain some of my decisions a little better.
    Mar 2011
    77
    [/QUOTE]
    I have one of these Izip/ Schwinn wheels. They're very light duty. The axle is only 10mm dia. The tire is suppose to be 3" wide, but actually is less than 2.5". It takes a bicycle type threaded-on sprocket or free wheel (although the brake disk can be thread-on or bolt-on). The chain on the stock sprocket is the tiny #25 or the 8mm T8F. They're used with 1kW or smaller motors.
    For use with a 10kW motor? You want to look for a heavier duty wheel.
