Likes Likes:  40
Page 15 of 15 FirstFirst ... 5131415
Results 141 to 142 of 142
Thread: Spaceweasel's GSX-V
  1. #141
    732
    I agree with Spoonman, except from my experience, redoing a learning project is starting a new learning project
    May as well start a whole new project, which you already did! That BMW will be sweet and I was wondering myself how one could mate a shaft drive to an electric output.
  3. #142
    436
    FOR SALE!
    Time to make some space so that I can get to work on the BMW EV. I disassembled the GSX-R down to the frame again to pull the old batteries. Now it is in the perfect shape for someone to do a first conversion. Motor, controller, contactor, sprockets, etc. are all there - you will just need to come up with your own battery solution. Everything is in Denver, and I can help deliver in a reasonable range.
    1992 Suzuki GSX-R w/ clean title
    Aluminum motor mounts
    D&D es-15-6 motor
    Alltrax 7245 controller
    Cycle Analyst v2.23 CA-HC
    72v-12v DC-DC converter
    JCA 200D 72v contactor
    Vortex 54t aluminum rear sprocket
    3 front sprockets (two new, one used)
    magura throttle w/dime city grips
    hi-low/ horn / turnsignal switchgear
    If you want them as well:
    misc. cables and wiring
    Triumph seat
    Battery box
    Motor, mounts, and contractor came off of Noah Podolefsky’s GSX-R build. Tires and brakes are in great shape.
    PM me with any questions!
