Likes Likes:  22
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 71
Thread: Black Widow reverse trike ratrodmoto build thread
    Status-free and luvin' it
    283
    Been a while since the last update
    I decided to add a rear seat cause... well I have a special friend and she has a little hot rodder ... So I grabbed a sliding seat frame from speedway motors and used it as a basis for an adjustable height mount for a child seat.. the box underneath is a subwoofer enclosure just places to mock up clearance.
    ImageUploadedByTapatalk1395552409.258285.jpgImageUploadedByTapatalk1395552451.955302.jpgImageUploadedByTapatalk1395552501.005993.jpgImageUploadedByTapatalk1395552527.816147.jpgImageUploadedByTapatalk1395552548.889673.jpg
    Mike Pipes
    283
    Built brackets to mount the seats to more slider seat framesImageUploadedByTapatalk1395552728.005701.jpgImageUploadedByTapatalk1395552742.105683.jpg
    Mike Pipes
    283
    Onboard air tank and compressor mount in progress. The air tank sits flush on top and the compressor along with solenoid valves and the control electronics will mount to the underside within the space of the frame.
    The top surface was literally shaped with the tank in place for the tight fit, clear packing tape made releasing easy and kept the tank clean.
    ImageUploadedByTapatalk1395553268.456230.jpgImageUploadedByTapatalk1395553346.155592.jpgImageUploadedByTapatalk1395553392.305946.jpgImageUploadedByTapatalk1395553426.823273.jpgImageUploadedByTapatalk1395553442.205760.jpg
    Mike Pipes
  4. Likes robo liked this post
  5. #24
    283
    Mike Pipes
  6. #25
    283
    Drive belts from Gates arrived, now to make tensioners!
    Mike Pipes
  7. Likes Skeezmour liked this post
  8. #26
    383
    I am really impressed with the cf work you are doing.
  9. #27
    283
    Thanks Spaceweasel!
    Mike Pipes
  10. #28
    283
    Been a long time since updating...
    Seats more finished out structurally, almost ready for padding and upholstery. The bolsters help make it more comfortable!
    ImageUploadedByTapatalk1410549173.001809.jpgImageUploadedByTapatalk1410549194.763581.jpg
    Mike Pipes
  11. #29
    283
    Steering column assembly getting there... made it a tilting column. When I bought parts to build the belt drive for the rear wheel, I got a few sizes of belts for mocking up and finding the best fit. So I decided to use an extra belt to make a vertical drop in the steering system got a little fine tuning but the proof of concept works great
    Mike Pipes
  12. #30
    283
    Also received a Pegasus Touch SLA 3D printer this past Monday and I'm tackling the learning curve like its nothing! Ran these Headway Battery clamps last night!
    ImageUploadedByTapatalk1410549804.083155.jpgImageUploadedByTapatalk1410549813.299630.jpgImageUploadedByTapatalk1410549824.617237.jpg
    Mike Pipes
  13. Likes CaptainKlapton, robo liked this post
