0
Waste to Energy through Landfill Gasification
Gasification is the thermal decomposition of organic materials at high temperatures in a limited oxygen environment. The process requires an initia
l heat supply to produce a combination of combustible gases like methane, hydrocarbons, hydrogen and carbon monoxide. This combination of gases is called ‘syngas’ which can be stored or combusted as it is produced. It is through gasification that biomass to be converted effectively. The most advanced form of gasification can provide for carbon capture which is one way of reducing carbon emissions in successfully combating climate change.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
