Results 11 to 20 of 21
Thread: Dealing With How To Turn on Your Bike
    367
    If you use LED's for all of your lights, you'll use less than 100 watts.
    Original build: http://vorworxemc.wix.com/vorworx
    Jun 2012
    98
    hmmm, we will have the usual headlights and turn signals, we will also have a charger for the tablet display, pump for liquid cooling, arduino, orion BMS (250mA), 2 motor controllers
    367
    Check these out... they will help considerably: Led Headlight Kit at Cycle Gear
    Only 24 watts compared to 55-60 watts halogen
  4. Likes theFREElaker liked this post
  5. #14
    2,420
    What's your budget and a guesstimate of all loads? (if you could, look up all the data sheets for your equipment.... I unfortunately won't have time the next few days).
  6. #15
    367
    Frodus, it appears your website needs some work.. there are no products when I click on any of the product links. Don't take that observation in a bad way, just that, an observation.
    Having built a website myself, I know how time consuming these things are. Then keeping it up-to-date is a full time job in itself. How much on-line business does it generate?
  7. #16
    2,420
    Yeah, I intended on having a full eCommerce website, but sales have slowed the last few years for the DIY market. I haven't added anything because it ended up that most people want very specific quotes. Best to email me and ask... E-commerce software that is freely available isn't really meant for a quote based system and drop shipping.
    But I did just update the website to make it more simple with just an About me and Contact. Thanks though.
  8. #17
    I use a Vicor DC/DC converter. It has an enable/disable pin. Floating is on, connected to ground turns the unit off. It's normally always on. I have my stock key switch wired so that in "park" it disables the DC/DC converter.
  9. #18
    2,420
    +1 on vicor. They sometimes need external components like a cap or trim resistor, but they're pretty solid.
  10. #19
    Edmonds, WA
    154
    I have the same setup as Noah. I bought a different DCC first (still have it sitting) and then bought the Vicor which floats or pulls down so I could use my stock ignition switch. My homemade BMS AFE is powered straight off the pack and uses less than self discharge rates, always powered.
  11. #20
    Jun 2012
    98
    So I assume its got a tiny battery inside or some kind of stored angry to use as a signal when that pin is grounded?
