Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Arduino Vehicle Controls / BMS Thread
    320
    I see a few members here and there mention that they are planning an Arduino this or that or BMS for their builds.
    I'm doing this too, and I thought I would create a place for us to share Arduino developments that might be helpful to others.
    If you are working on an Arduino project for your build, please feel free to share it here!
    I'll start.
    I am planning a complete Arduino vehicle control system eventually. Speed, amps, voltage info displays, charging control, Ignition and start-up sequences, fingerprint vehicle access, eventually BMS, and control of the 12v systems too, lights etc.
    I'm fairly new to Arduino, but I find the basic stuff is pretty straightforward and there are lots of resources to help. I like that you can make a small project to figure out how to use a sensor like the fingerprint scanner, and then incorporate it into a larger program. That's how I'm making slow but steady progress on my system.
    The first project I tackled was a 12v system control unit for my ICE bike. Sort of a Poor Mans Motogadget M-Unit. I figured it was a good starter project and first step towards my EV control system. I will be installing the first one in an ICE bike in a week or two, here it is:
    I'm using an Arduino Pro Mini, an FTDI board for programming (easy software upgrades), a variable voltage regulator to turn the bikes 12-14v into a steady 5v for the arduino, and an 8 relay breakout board. It controls all of the lighting, horn, and starter solenoid. I have routed the input from the front handlebar controls through a network cable to simplify the wiring harness, each control now simply grounds the appropriate wire when it is switched on. The speed of the flashing of lights, etc is all software controlled, and I've added a few clever tricks like turning all the lights off when the starter is pressed to send all available juice to turn over the engine, and multi clicks on the brake handle to turn on hazard flashers or parking lights.
    I'm planning to add a hall sensor for auto cancelling turn signals after the bike has traveled a certain distance, and maybe an accelerometer/gyro for crash, fall over shut off and engine braking activated brake light when the bike slows down quickly. Maybe an auto high beam dimmer with a photocell and an RFID ignition. The possibilities are endless really!
    If anyone is interested in the code (it's a bit messy at the moment), let me know. Eventually this will mutate into my EV vehicle control system
  2. Likes SplinterOz, Lex liked this post
    Member -UP-'s Avatar
    Apr 2015
    Finland
    33
    Follow -UP- on Tumblr Visit -UP-'s Youtube Channel
    Nice. I'll also use Arduinos and ATtinys on my build. I don't have much to share yet, but I'll post it, when I have some progress.
    Canberra, Australia
    This is cool. I have a m-unit on my bike and it simplifies things immensely. I am considering a similar unit for the car conversion along with a custom 7 inch TFT screen for the dash.
    SplinterOz
    From Australia'a Capital
    Jul 2007
    San Diego, California
    426
    Follow ElMotoMike On Twitter Add ElMotoMike on Facebook
    Visit ElMotoMike's Youtube Channel
    I have built a lot of things with Arduinos for the last few years now. They are extremely useful boards. I wouldnt mind checking out your code.
    - Mike
    1,082
    I'm still Arduino virgin but I would like to get started. I would like to read the current frequency, amplitude and direction on a motor phase and convert it to a variable audible signal in my helmet speaker.
    Let's see where I get with this.
    715
    Arduino virgins like myself could benefit from a list of resource/educational links. Are you guys soldering the boards from scratch? What special equipment and tooling is needed?
    Like this:http://www.intorobotics.com/arduino-...ces-need-know/
    Man there's a learning curve!!
    Nov 2013
    114
    This is super cool! Thanks for offering up your code as well, I don't know anything about Arduinos but the potential is certainly intriguing.
    Senior Member tomdb's Avatar
    Apr 2013
    202
    I am building a spot welder controlled by an micro.
    And working on a battery management system with an arduino master.
    Senior Member Athlon's Avatar
    Jul 2011
    Milan, Italy
    Add Athlon on Linkedin
    Another Arduino user here.
    on the forum I have pubblished the code for controllin the Zivan Charger ,
    right in this moment i'm writing the code for the Eltek Valere canbus charged ( the same of Brammo Empulse )
    my next task is to make the Eltek and the Zeva BMS talk each other via canbus (and also working as a logger)
    Nov 2013
    114
    Perhaps a subforum for Arduino projects could help keep all of this in one place?
