Results 1 to 10 of 13
Thread: How to find me1003 hub, can you help?
    Mar 2015
    ireland
    53
    I am struggling to find a correct hub to suit a me1003 motor.
    Just to be clear because I am not 100% that I am using the correct terminology for what I am looking for: I want a female to fit the the motors rotating out put which will have a sprocket attached.
    I have seen a few with the right inner diameter on eBay but never the right keyway, is it possible to key a key which fits one size on the outside and one on the inside?
    Also if there is a device which I could plug into the wall which would simulate a battery pack so I could test before my batteries are bought that would be pretty sweet as well (but this is less important.).
    Thanks in advance!
    andy
    Aug 2011
    Eastern Massachuesetts
    166
  3. Likes andy liked this post
    Senior Member tomdb's Avatar
    Apr 2013
    202
    Stupid Yankee measurements.
    22.23mm round with an 4.78mm keyway
    7/8 inch bore and 3/16 inch keyway
    example if you are in the states http://www.mcmaster.com/#roller-chain-sprockets/=yog1yj
  5. Likes andy liked this post
  6. #4
    Mar 2015
    ireland
    53
    OMG sooo helpful.
    Thanks ken will, the first is exactly what I was asking for when I mentioned a "a key which fits one size on the outside and one on the inside" and then second link is cool as well.
    Thanks a lot tomdb that's another awesome link but I had imagined getting a piece just like that but without the sprocket and then having it drilled and tapped so i could change the sprocket.
    Do you use sprockets / hub units from that site ?
    What do you think of them?
  7. #5
    Quote Originally Posted by andy View Post
    You could use a power supply, Mastech are decent quality. But you'll need a 100V model and those start at $300.
    Or if you already have a charger picked out you might be able to power the controller with it. Depends on what type of charger.
  8. #6
    Nov 2012
    40
    OMG sooo helpful.
    Why bother with drilling and so? Search on Ebay for sprocker 7/8 bore and you will find a lot of different sprocket you can use.
    http://www.ebay.com/sch/i.html?_from...ocket&_sacat=0
    You can take a standard key and remove lite on top so it fits key slot in sprocket. I did so for my sprocket.
    And if you want to test your motor a car battery will work fine.
  9. #7
    Mar 2015
    ireland
    53
    I just thought it would be useful to be able to interact with traditional or oem motorcycle parts, but the more I hear of the availability of these sprocket+hub pieces the more i think my original idea may not be worth the hassle.
    687
    For 7/8 bore....
    http://www.surpluscenter.com/Power-T...tional:3/4\%22
    Mar 2015
    ireland
    53
    thanks hopefully I should have what i need soon
    Mar 2015
    ireland
    53
    can anyone tell me what thread / bolt fits the inside of the me1003 motor shaft ?
    i all my spare bolt are metric so can't just try all I will need to order it.
    thanks !
