Results 1 to 7 of 7
Thread: Where to buy sprockets
    Feb 2015
    8
    Im really confused, i cant find sprockets for motenergy me 1004 shaft. If it will be possible, in europe. I need to use 520 chain, can anybody help me ? I need 12 - 15 teeth sprockets. Thanks a lot for help.
    101
    Those are coupler sprockets. I think what you want are these:http://www.surpluscenter.com/Power-T...ore-Sprockets/
    Also, the size 50 chain sprockets,like from the Surplus Center, will need to be machined thinner from .343" (~8.7mm) to .227" (~5.8mm) to fit the 520 chain that bedacz wants to use. This could be difficult because the teeth are heat treated (hardened), but not impossible. Sometimes the motorcycle chain does not have a good fit on the industrial sprockets even though they're made to the same nominal specs.-the tolerances could be different. Make sure all of the corners of the teeth are chamfered and cleaned up.
    Nov 2012
    37
    Can you use 530 chain instead, it will be much easier to find sprockets on Ebay.
    I don't know about European suppliers, but what you need is a standard #50 sprocket with 1" bore, machined down to fit 520 chain. 0.227" (5.77mm) wide is correct as stated above. Most sprockets aren't hardened unless it says so specifically, so you can have them turned on a lathe. I've done this with all my sprockets.
    If you can use 530 chain then a #50 sprocket will work without modification.
    Try these guys in France:
    http://fr.itafran.com
    Mountain View, CA
    804
    How about for 15mm or 20mm shafts like the RV-120 and RV-160 (for my scooter re-conversion)
