Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Leaf module: Top or Bottom Balance
    Feb 2015
    182
    I take mine down to 3.4/3.5 most of the time.
    That makes me feel better.
    The problem is, I'm using a HPM 600a Kelly controller; I get a huge drop in acceleration ~3.8v. It's a little worrying. I didn't have this problem with the Altrax 450.
    Feb 2015
    182
    Not 3.3, (80/22)=3.63 volts The most I've ever pulled from my pack is 50ah. resting voltage was about 80v. Definitely loose about 2-3 mph off top end after 3.8 per cell. My LVC is at 72V. I almost never hit it, only in colder weather.
    Oh, of course. I am so used to dividing by 24. Lol
    I'm definitely getting a top end drop but worried about the Huge drop off in the acceleration at 3.8V.
    You're not seeing that?
    224
    I top balanced mine.
    Quote Originally Posted by JoeReal View Post
    I'm not seeing this with my pack. Normally torque drops off at a certain RPM of your motor, not at a specific voltage of your battery pack. Could it be your controller settings dropping torque at a certain battery voltage to protect it?
    Senior Member Athlon's Avatar
    Jul 2011
    Milan, Italy
    Add Athlon on Linkedin
    probably the KV of your motor is too low and you are able to have full torque only above a specific voltage
    Check this ^^^^^
    I'm guessing you have the 120V HPM. Very likely under voltage is set near 90V, which is about 3.8V x 24. I think Kelly's start cutting back at 1.1 x under voltage value.
    Feb 2015
    182
    Yup. Exactly. Thank you guys.
    I had the lower limit set to
    84v (3.5v)
    Where
    1.1 * 3.5v = 3.85v
    Exactly where I was noticing the drop off.
    I tested it yesterday, I lowered the Lower Limit to
    78v (3.25v)
    Where
    1.1 * 3.25v = 3.575v
    I had substantially more range at full power.
    I think I'll keep it there. I don't think I will ever need to take my pack down to 3.25v. But like to know when I hit 3.575v, in case I'm not paying attention.
    Considering I can wore an economy switch to limit the amperage anyway, this function isn't really helping much.
    Thanks again guys. I feel MUCH better with this configuration.
