Results 1 to 10 of 17
Thread: Leaf module: Top or Bottom Balance
    Feb 2015
    182
    Hey guys,
    I have my 12 leaf modules bottom balance-
    I charge them to-
    Pack- 100v Max
    Highest cell - 4.185v
    Lowest cell - 4.142v
    Average - 4.166v
    The reason I charge to 100v is to not over charge any cell. I do not have a BMS (monitoring nor management).
    My question is-
    If I were to top balance- and get all the cells within 1/1000th of a vol. could I charge to
    Pack- 100.5v Max
    Highest cell - 4.19v
    Lowest cell ~ 4.19v
    Average ~ 4.19v
    I realize that the 0.5v pack may not seem like much, but it's more about having more cells in the 4.1-4.0 (the most energy dense volt) range for a longer period of time.
    I usually ride from 4.166v avg to 3.80 avg each day. I am noticing a large power drop off around 3.9v which is when I'm about to get onto the short highway part of my ride home from work. So the little bit extra power will mean a lot, everyday.
    Any input would be great.
    Thanks for the help guys,
    Joe
    Senior Member Athlon's Avatar
    Jul 2011
    Milan, Italy
    Add Athlon on Linkedin
    4.190 looks a little too high to me for LEaf cell , for greater life you should charge them at 4.180 or 4.185
    also right now some of your cell charge above the last transition voltages 4.150 , other stay below so you actually unbalancing your pack by stressing differently the chemestry of your cell every cycle.
    bottom balancing is also really dangerous because in the event of a charger failure you will for sure overcharge some cell and have a fire or venting , a top balancing will at least make the pack more resistant to overcharging (high voltage will be shared on the cells instead of just one)
    Feb 2015
    182
    Thanks for the reply, Athlon.
    Ok, so I should top balance them to 4.185. Then set my charger to 100.44v (when fully charged, the pack will be closer to 100.32v, so 4.18v per cell)
    Correct?
    From this seller site:
    http://hybridautocenter.com/HAC4/ind...=72&Itemid=631
    "In many cases it is recommended limiting the charging to 4.1 - 4.15V, (especially if not using BMS)."
    I charge mine at 4.10, BMS on at all times, also when riding , to protect weakest cell, and I do have one that drops off the cliff before others.
  5. Likes Athlon liked this post
    682
    I have 11 modules, no BMS. Charge to 90v. Never go below 80v. Over 100 cycles and counting....all cells within .05v
    Feb 2015
    182
    Hughes, do you top or bottom balance?
    Which do you think I should do?
    I rarely get down even near the cells lower limit.
    Thanks
    Jul 2011
    Milan, Italy
    Hugues uses an Orion BMS and top balance
    Feb 2015
    182
    Hey Phil,
    Wow, you bring them down to 3.3? Do you notice a large power drop off after 3.8?
    Also, how much energy do you have left after 3.8? In terms of distance per volt, I guess.
    I haven't installed my analyst yet, but I'm really curious to find out what my miles/volt is throughout the range of 4.2-3.2 v
    Right now it seems like I'm doing
    6.4 miles/10th volt from 4.1-3.9v and
    5.6 miles/10th volt from 3.9-3.7v
    1,772
    I take mine down to 3.4/3.5 most of the time. Been down to 3.0V under load at which point my controller LVC kicks in
    I have mine all top balanced at 4.165V using a PL8 charger. Bulk charge to ~116.5V on a 28s system, no BMS and no issues.
    682
    Not 3.3, (80/22)=3.63 volts The most I've ever pulled from my pack is 50ah. resting voltage was about 80v. Definitely loose about 2-3 mph off top end after 3.8 per cell. My LVC is at 72V. I almost never hit it, only in colder weather.
