Results 1 to 2 of 2
Thread: Read Alltrax serial with arduino and show on LCD
    Nov 2012
    40
    Original from this thread
    In 2013, before I discovered there is something called HC Cycle Analyst , for 3 month I used Arduino Mega to read out values from Alltrax Axe 7245 to show values on a 20x4 LCD screen.
    As I remeber it parts was :
    - Arduino Mega. I discovered I need a lot of CPU power to handle UART communication and send information via SoftwareSerial to SerLCD.
    - RS232 shield to connect arduino to Alltrax controller
    - Serial Backpack for LCD https://www.sparkfun.com/products/258
    - and 20x4 LCD screen simular this https://www.sparkfun.com/products/256
    SimpleTimer is a library to launch timed actions.
    Idea behind sketch is to ten times per second poll controller for voltage and current values, process received answer and update variables for Ah, voltage, current and Wh and to show those on LCD screen. If I update LCd screen every 100 ms it flicks a lot, so I update it every fourth reading.
    An hour contain 36000 100 ms, so current value read out is devided by 36000. In theory if my motor use 50A for 1 hour every 100 ms read out should be 50A and if I divide it by 36000 and add every reading together I get 50Ah after 1 hour.
    At now i do not have rs232 shield availabe and can not test it again.
    Here is my code. I be happy if someone else can use too.
    Code:
    #include
    HTML Code:
    <SimpleTimer.h>
    #include
    HTML Code:
    <SoftwareSerial.h>
    // the timer object SimpleTimer timer; //initiate SerialBackpack backpack and LCD screen #define txPin 7 //Pin 7 is one connected to SerialBackpack SerLCD SoftwareSerial LCD = SoftwareSerial(0,txPin); byte strValue[7]; unsigned long time; unsigned long latest; float Current = 0; float Voltage = 0; float Wh = 0; float currentCounter = 0; byte currentArray[7] = { 0x5B,0x04,0x60,0x00,0x00,0x00,0x41}; // output current byte voltageArray[7] = { 0x5B,0x04,0x39,0x00,0x00,0x00,0x68}; // output voltage int lcdOut = 0; void setup() { Serial1.begin(9600); pinMode(txPin, OUTPUT); LCD.begin(9600); backlightOn(); clearLCD(); timer.setInterval(100, repeatMe); } void loop() { timer.run(); } void repeatMe() { selectLineFour(); time = millis(); LCD.print(time - latest); LCD.print(" "); //Serial.println(time - senast); latest = time; lcdOut += 1; // Update LCD every 4th reading to avoid flimming if( lcdOut == 4 ) { lcdOut = 1; } Serial1.write(currentArray,7);// Ask AXE controller for current value if(Serial1.available()) { if(Serial1.peek() == 181) {// Does it start with B5? for(int i=0;i<7;i++) { // If so, fill array strValue strValue[i] = Serial1.read(); } Current = ((strValue[4])*16*16)+(strValue[3]); //calculate current value currentCounter += (Current/36000); // add value to AH counter } else // if B5 is not first char, empty buffer { while(Serial1.available()>0) // empty { Serial1.read(); // empty until there is nothing in buffer } } } Serial1.write(voltageArray,7);// Ask AXE controlelr about battery voltage if(Serial1.available()) {// do we have a answer in serial port? if(Serial1.peek() == 181) {// Does it start with B5? for(int i=0;i<7;i++) { // If so fill array strValue strValue[i] = Serial1.read(); } Voltage = ((strValue[4])*16*16)+(strValue[3]); //calculate voltage value Voltage = Voltage * 0.1025 ; } else // if B5 is not first char, empty buffer { while(Serial1.available()>0) // empty until it is empty { Serial1.read(); // read out until it empty } } } Wh += Voltage * (Current/36000); if(lcdOut == 3) { printValue(Current, 0); //Print out current value } if(lcdOut == 2) { selectLineTwo();// choose line two on lcd //LCDFloat(currentCounter,4); LCDFloat(Voltage,3); // Print out voltage value with 2 decimals delay(10); LCD.print(" V "); } if(lcdOut == 1) { selectLineThree(); LCDFloat(Wh,2); LCD.print(" Wh of 4420 "); //4420 was my battery pack } //LCD.print(" Ah ");} Current = 0; // does it need to be set to 0? } //LCD functions void selectLineOne(){ //puts the cursor at line 0 char 0. LCD.write(0xFE); //command flag LCD.write(128); //position } void selectLineTwo(){ //puts the cursor at line 0 char 0. LCD.write(0xFE); //command flag LCD.write(192); //position } void selectLineThree(){ //puts the cursor at line 3 char 0. LCD.write(0xFE); //command flag LCD.write(148); //position } void selectLineFour(){ //puts the cursor at line 4 char 0. LCD.write(0xFE); //command flag LCD.write(212); //position } void goTo(int position) { //position = line 1: 0-19, line 2: 20-39, etc, 79+ defaults back to 0 if (position<20){ LCD.write(0xFE); //command flag LCD.write((position+128)); //position } else if (position<40){ LCD.write(0xFE); //command flag LCD.write((position+128+64-20)); //position } else if (position<60){ LCD.write(0xFE); //command flag LCD.write((position+128+20-40)); //position } else if (position<80){ LCD.write(0xFE); //command flag LCD.write((position+128+84-60)); //position } else { goTo(0); } } void clearLCD(){ LCD.write(0xFE); //command flag LCD.write(0x01); //clear command. } void backlightOn(){ //turns on the backlight LCD.write(0x7C); //command flag for backlight stuff LCD.write(157); //light level. } void backlightOff(){ //turns off the backlight LCD.write(0x7C); //command flag for backlight stuff LCD.write(128); //light level for off. } void serCommand(){ //a general function to call the command flag for issuing all other commands LCD.write(0xFE); } //Function to write out float values on LCD //http://forum.arduino.cc/index.php?topic=46688.0 void LCDFloat(double number, int8_t digits) { if (number == 0) { LCD.print('0'); return; } if (number < 0) { LCD.print('-'); number = -number; } // handle negative numbers int8_t e = log(number) * (1/log(10)); // determine exponent if (digits > 7) digits = 7; else if (digits < 1) digits = 1; // shape digits if (number >= 1) digits--; number += .5 * pow(10,e-digits); // rounding // print out if (e >= digits) { e -= digits; number *= pow(10,-e); LCD.print((uint32_t)number); for (; e>0; e--) LCD.print('0'); } else { const uint32_t I = (uint32_t) number; number -= I; LCD.print(I); uint32_t F = (uint32_t) (number * pow(10,digits-e)); if (F == 0) return; LCD.print('.'); for (; e<0; e++) LCD.print('0'); while (F % 10 == 0) F /= 10; LCD.print(F); } } void printValue(float value, int position) { goTo(0); if(value >99) { LCDFloat(value, 3); } if(value >9 && value<100) { LCD.print(" "); LCDFloat(value, 2); } if(value <10) { LCD.print(" "); LCDFloat(value, 1); } delay(10); LCD.print(" A "); }
    Jul 2007
    San Diego, California
    426
    Follow ElMotoMike On Twitter Add ElMotoMike on Facebook
    Visit ElMotoMike's Youtube Channel
    Very cool.
    I have been working on a GPS speedometer that would display info onto a 480x320 lcd screen via the Mega... but it also had a horrible flicker. After a few weeks of trying to find a fix, I upgraded to the Due because it will display without a flicker. Perhaps try that out?
    This was the video that convinced me to upgrade.
    - Mike
