Results 1 to 2 of 2
Thread: Agni max voltage
    Nov 2012
    38
    Agni max voltage
    I am building a bike with leaf cells and I want voltage to be as high as possible max 90 V.
    Maximum voltage for Agni 95R is 84 V according to service manual. If higher voltage used - motor maximum speed exceeds 6000 RPM and there is risk that the armature burst apart.
    But if I gear my bike such way that rpm never exceeds 6000 will it be safe to use Agni95R?
    Say I want my bike maximum speed be 120 km/h. Circumference of my rear wheel is 2 meter so at 120 km/h maximum RPM of rear wheel will be 1000. if I use 15T in front and 62T sprocket at rear = 4. 133, motor RPM will be 4133.
    To reach motor maximum RPM 6000 bike's speed need to be over 176 km/h, and I never will reach that speed...
    Do I miss something?
    684
    Just use 11 leaf cells and gear for 5% more then your max speed not to exceed 6000 rpm. My bike is geared for 13/72, top speed ~75 mph, rpm just under 6K. Keep in mind the Leaf cells voltage curve is steeper then Lifpo4 so your top speed is changing as you drive!
  3. Likes nedfunnell liked this post
