Results 1 to 10 of 18
Thread: Searching for a motor..
    Mar 2016
    9
    Hello everyone,
    I am trying to find motors that fit a specific set of constraints (or as close as I can get).
    DC preferred but not required. 8-1/2 inches or less in diameter. 2-1/2 inches or less in length. 4kw-10kw rating. 200V continuous.
    Any help provided is much appreciated!
    Thank you, Redshirt.
    2,470
    200V continuous? Is that your battery pack voltage?
    There's a controller in between, usually, that uses PWM to control the motor, so you may have 200V on one side, but the motor itself may see varying levels of 200V on its input.
    What is this for? Pack size?
    2.5" length is going to be pretty hard to find, if you can even find it.
    Aug 2011
    Eastern Massachuesetts
    166
    Quote Originally Posted by Redshirt View Post
    1/2" for each bearing, and 1" for brushes, leaves 1/2" for the rotor..??
    Mar 2016
    9
    200V motor voltage.
    2,470
    200V motor voltage.
    I get that 200V is the max, but is it just going to be sitting there at max RPM the entire time?
    Usually there's a motor controller involved, to control speed and limit current.
    There's not likely a motor that small on the market for what you want to do. There's not really a reason for a 200V motor that small with that low power.
    Mar 2016
    9
    Well, usually max is higher than continuous but for these purposes just drop a link for either/both.
    Mar 2016
    9
    Please post any links to motors you find, thank you.
    What is your application? There might be an alternative that would work if you can change some of your constraints or tell us more about what you're trying to do.
    Some hub motors are close to that size - Crystalyte H40 for example. But not 200V and not 4kW. The Crown is close to 4kW, but a little larger and still not 200V.
    http://www.crystalyte.com/
    Mar 2016
    9
    Nice, thanks podolefsky!
    Mountain View, CA
    804
    Can you use an outrunner? How about the revolt RV120-short (http://www.revolt.org.il/rv-120/rv-120pro-short/)?
    http://www.revolt.org.il/wp-content/...1/RV-120Sh.png
    It says max 96V, but you could contact them and maybe have it wound with a lower KV (rpm/volt) so it can handle the higher voltage.
