Results 1 to 7 of 7
Thread: Neck deep in projects
    110
    Hi all. Been away a long time and now I need information. I have done a lot of research and find that motorcycle tires and car tires are made differently where they fit the specific rims.
    I am gathering parts to build a leaning version of the Can Am Spyder. I nearly bought spindle assemblies until I found that the Spyder rims are car tire specific and motorcycle tires could roll off the bead in cornering.
    I have looked as much as possible for lug mounted motorcycle wheels, but, have found nothing. Motorcycle wheels are supported on both sides of the wheels, but, I know there is/was one sided forks and swingarms. I just can not find them to see how the wheels are supported.
    I have no heavy duty machines to turn spindles and mod the Spyder assemblies. I am lacking options to continue with this project. I already have a Goldwing complete swingarm with new wheel and tire. That wheel uses lugs like a car wheel. However, it is wayy too wide for front wheels. I have a 30S 1P Chevy Volt battery to use in a straddle type configuration, similar to the Arcimoto platform.
    I have built a mongrel bici-moto, using bicycle parts and motorcycle forks. It uses a 20S1P Volt battery. It gets me around, but, is not sufficient as a 20 miles round trip on the asphalt, grocery getter. It does handle well with my wife and I on the rocky, slick dirt road to our house. I put an electric scooter hub motor on it , so, it rides low and center of gravity as acceptable.
    Anyone have any input here would be greatly appreciated.
    Thanks, Harold in Costa Rica
    Member Duck-Stew's Avatar
    May 2016
    ABQ, NM
    72
    Look at a Honda NSR150 rear wheel.
    110
    I have searched using all sorts of different terms. The Honda wheels are something I can make work. Found some Honda Hawk rear wheels, also.
    Thank You very much for the heads up.
    Harold in CR
    Senior Member tomdb's Avatar
    Apr 2013
    202
    aprilia af1 125
    honda VFR
    You searched for "single sided swingarm"?
    110
    tomdb, yes I searched for single sided swingarm, I have the goldwing swingarm, single sided motorcycle wheel, edge spoked motorcycle wheel, dished motorcycle wheel. I found Ducati hypermotard wheels at $450.00 and up and the carbon fibre version for $850.00 and up.
    I never searched for rear wheel, figuring it would be difficult to mod, down here, in the jungle.
    Thanks for additional info, Harold
    Apr 2013
    202
    Shit I forgot you are in Costa Rica. That would limit your wheel choices quite a bit. But is a honda vfr 750 rear wheel too big?
    110
    I am building this as an all electric reverse leaning trike. I was going to build from the ground up, but, registering here can be tricky, so, have an eye on a "big"? 2 wheel motorcycle, and will know more when wife returns from sons house. He has it and price is free. That will then get stretched out and the 2 front wheel attachment will be built. Want to keep the front tires at 3" wide or so. Rear will be 5.5" wide or so for better traction up a rocky dirt road to our house. Chevy Volt battery at 96-123V as frame room allows.
