Results 1 to 8 of 8
Thread: HPEVS encoder
    Senior Member chdfarl's Avatar
    Dartmouth Ma.
    177
    HPEVS encoder
    Would one of you happen to know the brand and model encoder used on the HPEVS AC motors.
    Nov 2010
    12
    Mine needed to be replaced on an AC30 and although I figured out the manufacturer, the part was an OEM spec and thus not available (cheep) off the shelf... Hope that helps. Bill at HPEVs found me one off a junk motor or out of a drawer of parts. Check with them.
    2,426
    Let me know, I sell HPEVS equipment and parts and can get you one no problem.
    Dartmouth Ma.
    177
    Hi guys I appreciate the replies. I spoke to a guy at HPEVS whose name I think was Bill and he quoted a price of $50 for that encoder. That doesn't seem bad but it isn't for one of those motors. I've bought two induction motors. One is a lesson the other is a gm eassist motor. They'll be used with Sevcon espAC. The leeson motor has no encoder and the gm has a resolver to my understanding. The espAC and Gen4 mmanuals both spec either a constant current or open collector encoder.
    2,426
    You'll just need to follow the specs in the espAC controller manual. The encoder is programmable as far as the pulses per revolution. I think they're AB encoders, but you'd need to check. I doubt the encoder would be the same for you as with the HPEVS motors.
    Dartmouth Ma.
    177
    Why do you say that?
    I figured if they were AB encoders then it would be a matter of configuring the parameters in DVT like thePPR. The manual mentions the same SKF or Thalheim eencoders as the Gen4 manual but those seem pricey.
    2,426
    Physically different I mean. The encoders they have are made to fit the HPEVS motors on the non-drive end bell, beneath the fan.
    Dartmouth Ma.
    177
    Here's a picture of the two motors
    What would be a suitable encoder and where would it be bought. I looked on Mouser and digikey and found an HEDS 5500-S13
    http://www.digikey.com/product-detai...?fullsite=true
    That's why I was trying to find data on the hpevs encoder to compare and contrast as that one is a know used item.
