Results 1 to 6 of 6
Thread: Leaf pack
    Aug 2014
    4
    Leaf pack
    Hey all,
    Just looking for some input. I have done probably the base amount of research. But this is semi-local and seemed like a steal.
    https://www.ebay.com/itm/222147419465
    I know you can't guarantee that all the cells would be good. But I was wondering if I planned on building two bikes max(60mph top speed and 40 mile capacity) my numbers say about 7kwh needed per bike. Would you think I could salvage enough cells to manage?
    Also, it's probably a long term project and storage/balancing these cells if they're in an uninsulated/unheated shop over the winter in Michigan. Would that be a problem?
    I know it's pretty basic questions. Apologies. Just wanted some veteran input. Thanks!
    Nate
    849
    Ammadien,
    I am not a Leaf expert, but the item pictured in that ad is NOT a Leaf traction battery. It is a Nissan Murano Hybrid battery.
    http://www.nissanpartsdeal.com/parts...e-battery.html
    Aug 2014
    4
    Right on. Thanks for the link. You're right.
    465
    My opinion is that the batteries could wait until you need them, especially if this is a long term project like mine was. You will end up finding a better deal down the road and they wont be sitting around not being used in the mean time, Just my 2 cents
    465
    that same pack is here for a whole lot less: http://www.ebay.com/itm/152248316758...%3AMEBIDX%3AIT
    849
    Stevo,
    The 8 module pack you linked to is not the same pack. That is part of an early Leaf traction pack...pre-lizard chemistry. The modules look like this.
    http://hybridautocenter.com/HAC4/med...d/p1140453.jpg
    The later modules, with the improved chemistry, look like this.
    http://hybridautocenter.com/HAC4/med...1connector.jpg
    I have no ideas what voltage or amp hour that Murano hybrid pack is.
  7. Likes Stevo liked this post
