Likes Likes:  38
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 78
Thread: VOR.WORX.EMC.v3.0
    Senior Member Nicman's Avatar
    Jackonsville, FL
    105
    What do you think your total bike weight will be after everything is installed? If its near 300Lbs this thing will be a rocket.
    731
    Easily over 300 lb... Hoping for 350 - 375... I'm sure it will still be a rocket. I hope the throttle will have a smoother feel than the AXE had. If I come across a deal on a good used Domino, I may still try that as a future upgrade over the Magura.
    KnuCkelHeaD HotrodLambretta's Avatar
    Jun 2018
    San Francisco
    9
    Follow HotrodLambretta On Twitter Add HotrodLambretta on Facebook
    Visit HotrodLambretta's Youtube Channel Visit HotrodLambretta's Vimeo Channel
    I dig it!!!
    Have you filmed any videos of it???
    Jason
    731
    Maybe someday...a buddy has a gopro and software, said he would help make one.
    This weekend I figured with all this extra torque and hp added, I'd better gussy up the frame
    I've got the Sevcon and ME1616 mounted and I'll be wiring the Sevcon next. I'm in the process of fabin up the battbox. It's kinda like a 3d puzzle... it became obvious the cooling system wasn't going to fit and needed to be redone
    I lucked out and found a guy in Eureka that buys Estate sales and sells items on eBay... he had a garage full of boxes of odds and ends motorcycle parts from these sales... I found the perfect radiator. It says Kawasaki, neither of us knows what model it's for, but it fits this build to a T.
    2,627
    Steve,
    Did you purchase the programmer from me?
    I'd like to get a different file loaded on there, than the one you had months ago.
    731
    Yes. Do you not keep records of what you sell to customers? I'm sure you've gotten more clients and probably overloaded with your primary job as well as running a side business. I understand. I never downloaded the software because I'm not ready for that stage yet. Getting much closer though. Painfully close
    2,627
    Steve, I do, but I've a huge increase in customers in the last 4 months and couldn't recall. I just wanted to check.
    Let me know when you get there, because we'll want to update it.
  8. Likes Spaceweasel liked this post
  9. #18
    731
    Sounds good, Travis. Thanks for all your help and input. YOU ROCK!!
  10. #19
    731
    Well, I got the Sevcon harness wired up ... I tried to tidy up this plate of spaghetti as well as I could.... I hope I didn't break any soldered unions stuffing all of this pasta into my ex-fuel tank!! I guess I'll find out soon enough
    Sent from my SM-T377V using Tapatalk
  11. Likes Spaceweasel liked this post
  12. #20
    731
    Had time to tidy up the fuse box a bit today.
    These WAGO connectors are handy to connect a bunch of common ground wires together.
    https://www.amazon.com/Wago-221-415-...F7EJRAJHFY85F5
    I squeezed some silicone grease into each hole when I inserted the wires to make it more water proof. I'll see how well they hold up to vibrations and road bumps.
    This thick, medium dense foam rubber is great for securing relays. This is the turn indicator relay/blinker.
    I also used this foam rubber to secure the key switch relay, hidden and siliconed inside the foam rubber, below:
    And, of coarse, I had to add some stickers! HeeeHeeeHeeee ...Hey! Big Oil...
  13. Likes frodus liked this post
