Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: BMS-24 protection/display 2-24 cells 3.2 3.7 Li-Po Li-Ion
    Jul 2016
    31
    https://community.electricforum.com/...alancer/6523/8
    This thing is cool. It plugs into your Lithium Battery pack. It can do so many different things, I am interested in it as a "State of Charge display". You can choose how you want the state of charge to show up. It has 3 different styles of showing you how full or empty the battery is. Its very cool/
    Oct 2016
    Salt Lake
    30
    have a couple questions:
    what is the refresh rate of the power meter, specifically current draw?
    Do you know if the USB has any ability to allow output of the information?
    I understand there may not be an app but is it possible to send connect to the microcontroller and read the registers?
    Thanks!
    Jul 2016
    31
    I would have to ask designer. I'm a hardware guy.
    As far as I know USB is for loading upgrades only.
    I can get you information on processor if it helps.
  4. Likes Hopster liked this post
  5. #14
    Oct 2016
    Salt Lake
    30
    Alright I just sent money to your Paypal. I'm going to give it a try!
  6. #15
    Jul 2016
    31
    Going out priority in the morning.
    Very simple to set up and use.
    Counts cells when first connected. Then goes to work with default settings.
    Only thing that's puzzling, bms inputs are 3 sets of 9p jst. Ports.
    Last pin of first port is same as first pin of second port. Etc.
    In other words, pin 9 and 10 is the same. Pin 18 and 19 same.
  7. #16
    Jul 2016
    31
    I guess this is standard in rc equipment. For balancing 3 discrete 8 packs.
    Does that make sense?
