Results 1 to 10 of 19
Thread: Kelly KLS8080 Auto Identify Help
    Feb 2017
    Chicago, IL
    32
    Hey all, I have a 96V, 300A Kelly KLS8080IPS that I'm trying to get running. I'm in contact with Kelly but so far they haven't been able to resolve my issue.
    As far as I know (and according to Kelly) all my motor and sensor parameters are set correctly. I write "170" to the identification angle field, wait, power cycle the controller, and then it begins its routine. It appears to simply be stepping through a full 6 commutations. After that, you're supposed to get a "reset error" in the monitor window, but this never comes. I've waited a long time and it never goes to "85" nor throws any error or anything.
    Has anyone experienced this and resolved it? Is there a way to manually configure the identification angle? Is there CLI that I can access and get more information as to what's going on?
    Thanks.
    Oct 2016
    Salt Lake
    50
    After Reset, If you turn the throttle does the motor spin?
    If that's the case then i wouldn't sweat it unless you find that your efficiency is terrible.
    Also if you are using the app try using a laptop or vice versa?
    I have found tablets to be more communication stable then using an android phone
    good luck.
    Feb 2017
    Chicago, IL
    32
    Quote Originally Posted by cmcnall View Post
    It will twitch and/or whine (I watch the current to make sure it's not doing anything bad), but not spin. I was able to get it to spin if I turn the field drive off (rotor un-magnetized), but I think in that case it's sort of behaving like an induction motor. If I apply any load whatsoever it stops, naturally.
    good luck.
    I'm using a laptop. Though sometimes it has trouble connecting initially, I do see throttle input reads and stuff like that so I know I'm talking to the controller.
    Thanks.
    Mountain View, CA
    807
    It's been a while since I setup my KLS-8080I on my bike, so unfortunately, I don't remember much of the specifics now.
    however, when I did it, I made a video. I'm not sure if it'll help, but maybe there will be something.
    Good Luck.
    Feb 2017
    Chicago, IL
    32
    Ha, thanks, I've watched your video twice now looking for clues/differences. One is obviously the I vs IPS distinction but beyond that I'm doing what you're doing and my motor behaves just like yours during the "identify" routine.
    Thanks, your videos are helpful.
    Mountain View, CA
    807
    Quote Originally Posted by ldopa_chicago View Post
    Bummer. It was a long shot.
    From what you mention though, I don't think I ever received a "reset error" in the window either. I just reset the controller and re-read the config.
    Have you tried swapping the phase wires and re-trying the autoconfig? (I'm absolutely grasping at straws here, but since the magic doesn't seem to be working, this is something i'd try).
    Feb 2017
    Chicago, IL
    32
    No, I haven't swapped phase wires yet, but that's definitely worth trying. Theoretically it shouldn't matter but...I have nothing to lose!
    Mountain View, CA
    807
    yes, exactly.
    maybe also make sure the hall sensor wires are correct and/or swap them up too.
    Long Island, NY
    246
    Try raising the CPU power to 24 volts I had trouble at 12 volts very similar to what you're getting
    http://www.enertrac.net
    http://www.evalbum.com/2568
    Mountain View, CA
    807
    Quote Originally Posted by markcycle View Post
    Right! I run mine at 24V on @markcycle's recommendation (well from running a my original Kelly KBL controller).
