Results 11 to 20 of 40
Thread: AC-23 Motor not spinning with Curtis 1238 controller
    Dec 2015
    Philadelphia, PA, US
    42
    Those controllers are particular about the order in which you turn on and off certain inputs, for safety reasons.
    From what I recall, Interlock should be completely closed before turning on KSI. If interlock opens, you must cycle KSI.
    Glad you got it working.
    Thans Frodos and Huges. I was worried the motor might be a bust as it was on the motorcycle when i welded few tacks
    Pictures attached. Still have a long way to go to get it road worthy. Pulley ratio is 5:1. If the motor gets too hot on drive then i can swap out the drive pulley for a 28 teeth brining the ratio down to 6.5:1
    Now i need to figure out the BMS connections. Thats something i am a little scared off as it can mess with the batteries
    IMG_20170228_203237.jpgIMG_20170302_215321.jpgIMG_20170327_215122.jpgIMG_20170405_212841.jpgIMG_20170405_212856.jpg
    I'll also make a video on the connections for people like me who are new to all these electronics and post it on youtube.
    Code 28 is motor temp hot cutback. That sounds more like a bad connection to the temp sensor.
    Glad you got it working. Yes, you either need interlock connected to controller 12V or set it to type 2 (interlock turns on with KSI). Make sure it's controller 12V (pin 25) and not your system 12V (they need to be isolated).
    You can turn interlock and KSI on/off in any sequence.
    There's a setting called high pedal disable (HPD) that checks throttle <25% before interlock is enabled, or it throws code 47 and cuts power. It might be enabled for golf car programming, but I'm pretty sure it's turned off for their standard auto/motorcycle program. Either way, if throttle is 0 when you turn on it won't fault.
    By the way, bike is looking awesome!
    1,086
    Pretty cool build !
    we have pretty much the same gear,
    can't you reach a ratio of 7:1 with this rear sprocket ? i have 7.04 with 176 tooth on wheel and 25 on motor
    watch out when you connect your BMS, you can also damage the electronic of the BMS if you invert your wires. First you need to connect all your wires to your battery, then you check manually with a voltmeter that you got them in the right order on the BMS connector, then you can plugin the connector in the BMS. They also sell a tool to check this, but it can be done manually.
    Junior Member Nando's Avatar
    Nov 2015
    San Francisco
    23
    Milton, that is a very impressive build. Looks like you built the frame and the front suspension, wow. Building the whole bike from scratch, hope it goes smooth.
    Current R1200RT, previously FZ1, HawkGT, Nighthawk 650, XS650. Loved every single one of them, now it's time for an electric bike!
    Aug 2011
    Eastern Massachuesetts
    166
    I like it!
    It reminds me a little of Graucho's bike.
    824
    Cool. What color ya gonna paint it? Mural?
    Dec 2015
    42
    Thanks podolefsky
    Dec 2015
    42
    Pretty cool build !
    I am keeping that ratio as an option. My pulley is from Gates and they have quite some options for drive side pulley. If needed I can replace the drive side with a smaller one.
    Dec 2015
    42
    Quote Originally Posted by Nando View Post
    Yes Nando. I built every thing from scratch including the front suspension and rear swing arm. Also trying to figure out the design for the handle bar since the entire bike is curve, would concentrate on some big bends rather then small bends.
    Right now there is one hurdle. The rear pulley is a tad wobbly. One of the bolt hole is not centered. Will have to figure out a way to do that.
