Results 21 to 30 of 40
Thread: AC-23 Motor not spinning with Curtis 1238 controller
    Dec 2015
    Philadelphia, PA, US
    42
    Quote Originally Posted by Ken Will View Post
    I like it!
    It reminds me a little of Graucho's bike.
    Attachment 7346
    Thanks ken.
    Dec 2015
    42
    Cool. What color ya gonna paint it? Mural?
    Thinking of either keeping it bare metal finish it a bit and just clear coat it or go with matte black and bronze. But there is a long time to for that...
    1,086
    Quote Originally Posted by milton View Post
    I am keeping that ratio as an option. My pulley is from Gates and they have quite some options for drive side pulley. If needed I can replace the drive side with a smaller one.
    You'll probably need to ventilate your motor very well. I'm running 7.04:1 and I had to do the following:
    - add 12v radial blower to force air into the openings on the shaft side to ventilate rotor
    - add 12v fan underneath the motor to ventilate stator
    - remove the bell shape cover to help the mechanical fan to suck air out of rotor
    The controller also sits on heatsink which are ventilated by two 12v blowers which exhaust is blowing on top of motor.
    Which belt have you used ? The Gates Carbon GT ? It has blue teeth, that's the only one which can handle this power in that width and pitch 8 (I presume).
    Dec 2015
    42
    Yes i got the Gates Carbon GT 1400mm length 8mm pitch. Here is the latest picture with the battries fit in. I have the batteries mounted but dont have a picture of that yet.
    Still working on the ventilation aspect for the motor and Controller. Will probably have liquid cool for controller since its sitting on a chill plate. I was thinking of a heat sink as well but will decide on that after a trial run.
    The motor's bell shape is outside the bike frame. so it should be good out there.. It might help adding a blower on the shaft side.
    Dec 2015
    42
    has any one used the Domino or Magura throttle? I wanted to know the wiring with Curtis 1238. I wired it up yesterday,
    - white throttle wire to pot low on curtis controller (Purple and white wire)
    - Black throttle wire to pot wiper on curtis controller (Yellow and white wire)
    - Light blue throttle wire to pot high on curtis controller (Black and white wire)
    When i turned on the switch the motor just went high, even when i twisted the throttle the motor did not slow down. I tried reversing the pot high and pot low wires but still the same.
  6. #26
    2,676
    Did you program the controller for the correct throttle type? Normally they're set for 2-wire by default. You're using 3-wire.
    What pins are you wiring the throttle to on the sealed connector on the Curtis?
  7. #27
    Dec 2015
    42
    Pin 15, 16 and 18
    If I want to do a 2 wire throttle what pin should i use? Domino has a two wire configuration also. They also have two wire for microswitch. I dont know what that is for though.
  8. #28
    2,676
    How is your curtis configured? Do you have a programmer?
  9. #29
    Dec 2015
    42
    I do not have a programmer handy but it did work with a another potentiometer with a three wire with a high, middle and low connection. I did not try with the domino throttle earlier
  10. #30
    2,676
    Can you point me to your documentation for the Domino? And what documentation you're using for wiring the Curtis?
    See this:
    http://curtisinstruments.com/Uploads...638E_RevC3.pdf
    page 6.
    Throttle HIGH is pin 15
    Throttle WIPER is pin 16
    Throttle LOW is pin 18
    According to this:
    http://electricmotorcycleforum.com/b...p?topic=5252.0
    you have White is Throttle low, Black is throttle wiper, and Blue is throttle high.
    Have you tested the throttle with a multimeter?
    Are you sure you have the motor phases in the right direction? If they're backwards, it won't align with the encoder, and could spin out of control.
