Likes Likes:  15
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 76
Thread: Ludicrous idea time
    Senior Member tomdb's Avatar
    Apr 2013
    202
    http://evalbum.com/5094
    Almost the same, but slightly more ludicrous.
    http://www.instructables.com/id/How-...ic-Motorcycle/
    even instructions on how to do it
    Apr 2013
    202
    435
    Transmission (2004 k1200GT)
    1st gear: 2.05
    2nd gear: 1.60
    3rd gear: 1.27
    4th gear: 1.04
    5th gear: 0.90
    6th gear: 0.82
    Final drive (2006 K1200S) 2.82
    This should give me choices from 5.78:1 to 2.31:1.
    435
    Some de-ICEing projects go quicker than other.
  5. Likes Richard230 liked this post
  6. #15
    435
    What are ElMoto's thoughts on the Curtis 1231C-8601 paired with a Warp9?
  7. #16
    Maine
    212
    You'd be better off with a smaller motor and bigger controller (ex. Z1k). It really depends on your goals. Also, while the tranny idea is neat, unless you're racing it's not really necessary. Then again it's not that big, lol. Have a look at the ImPact 9 also.
  8. #17
    435
    The transmission is mostly to connect the motor to the shaft drive, while achieving both offset (centering the motor) and the appropriate reduction. The ability to change ratios is a bonus.
    I'm not familiar with the Impact 9 - do you mean the Impulse?
    Yes, a smaller motor would probably be more efficient. But it wouldn't be as interesting.
  9. #18
    435
    Cut down a K1200LT bellhousing to connect the motor and transmission.
  10. Likes Richard230 liked this post
  11. #19
    435
    Connection spacing issues
    Ideas? The Lovejoy L110 jaw connectors I got are huge. I hadn't counted on the extra spacing. The L95 I picked up to check sizing are the right size but are underrated for the torque. They make a size in between, but that means they will be slightly too big AND slightly underrated.
  12. Likes Richard230 liked this post
  13. #20
    435
    Here is the drivetrain mocked up into the frame w/ suspension. Not having final spacing on the connection between the motor and transmission shafts makes me nervous about front wheel clearance.
  14. Likes Richard230 liked this post
