Results 1 to 7 of 7
Thread: 520 Chain and Sprockets for sale
    Oct 2016
    Salt Lake
    30
    I downsized from a 520 chain to a 420 chain.
    For Sale $125: plus Shipping.($20 in US not sure elsewhere)
    70T rear sprocket, Fits Ninja 250
    16T and 14T front sprocket, fits Motenergy Motors
    126 Link 520 O Ring Motorcycle Chain.
    All Have about 400 miles on them.
    683
    Next you need to upgrade to Altrax SMP72400.... the pull is MUCH stronger than the sluggish Kelly! MUCH!!
    226
    Quote Originally Posted by cmcnall View Post
    I am interested, but I need to check if the rear sprocket will fit my GPR-S. Can you share the bolt circle diameter, hole diameter, etc? Also, would you be open to an offer?
    Edit: I am in Utah, and travel to Salt Lake often enough- I could pick it up, and check out your build, if you were open to it!
    Oct 2016
    Salt Lake
    30
    6x 10.5mm bolt holes 130mm on center diameter.
    Center hole is 110mm
    I'm open to an offer especially if you pick it up.
    hope it fits.
    226
    hope it fits.
    Cool, I will hop outside and take some measurements. I may be able to make it work by drilling for my 4-bolt pattern. Where in SLC are you?
    226
    Bummer- no such luck, my bolt pattern is a measly 75mm diameter. If I had this sprocket in the shop, I might make an adapter, but as long as I'm having something machined, it's probably cheaper altogether just to make a new sprocket. It'd be neat to meet up with you sometime anyway, though!
    Oct 2016
    Salt Lake
    30
    too bad, let me get my bike put back together then i'll have you over. I'm at the bottom of big cottonwood canyon.
    Also if you want the chain and front sprockets I can part with them cheap.
