Results 1 to 6 of 6
Thread: Authentic, original serial-numbered Briggs ETEK
    Junior Member Ted Dillard's Avatar
    20
    This is the real deal. Photos and description on eBay:
    http://www.ebay.com/itm/142502209043...84.m1558.l2649
    348
    That might be a very good upgrade for me that I can use right now... if it fits my current set up without too much required modification. I am running a ME1003 and Alltrax AXE7245. If this AXE will work, and the motor's face mounting holes are the same as the ME1003, I may bid on it.
    But I need to know the other dimensions of the motor to see if I can make it fit without too much hassle... because it will only be a temporary upgrade for me.
    Original build: http://vorworxemc.wix.com/vorworx
    20
    It works great with the AXE 7245. It's got the same mounting holes as any of the Motenergy motors, a NEMA C-face if I remember correctly. However, I'll caution you, it doesn't have the same low-end torque as the ME1003. Granted, it's about half the weight, but I considered the 1003 an upgrade from the ETEK.
    20
    I just found the photo I took of the bike that ran this little beastie:
    I'm trying to remember the exact weight - with a tiny lipo pack, I believe it was 210-215 lbs. Top speed was around 90mph. It was a 1971 Yammy R5 frame with all the standard race mods.
    20
    Last day of the auction! It's still under $300!
    20
    SOLD
