Results 1 to 4 of 4
Thread: 2 motors-1 throttle
    Member E-tron's Avatar
    52
    2 motors-1 throttle
    Is it possible to run 2 of these motor http://tncscooters.com/product.php?sku=106170
    with one throttle signal?Of course the controller should stand up with higher current...but is this possible?
    1,918
    One throttle and two controllers/motors is better.
    Juiced Drag Racing
    Only2Jakes
    I've been thinking of this. Motors in either series or parallel connected to a chain then to rear sprocket. Both are connected to the same controller ~ Kelly 300A controller. And lots of lipo Running the 48v motor at 66.6v would be pretty fast!
    2,647
    it depends on if the throttle input signal references ground or not. If so, just make sure they're wired parallel. If not, it may be a bit harder, as they might reference their own internal ground, so youd have to do some testing.
