Results 1 to 8 of 8
Thread: shaft drives
    Feb 2018
    shaft drives
    Hey the search feature isnt pulling up anything on shaft drives and I was wondering how much more difficult they are to work with. Considering using an old goldwing.
    435
    The main issue seems to be gearing the motor to the shaft. You will need at least 2-1 to get the shaft gearing to the right ratio.
    Feb 2018
    I still really want to use a goldwing, can I use a hub motor and bypass the shaft drive nonsense
    Mar 2016
    21
    of course, why not! : )
    Member Duck-Stew's Avatar
    May 2016
    ABQ, NM
    80
    I looked into it a bit. The only close to usable reduction ratio in a shaft drive is the early Moto Guzzi at ~4.7:1. All others seem to hover around 3:1 which would require further gear reduction to achieve the roughly 5:1 which is commonly used.
    I'm a noob at this so if there's a way to make ~3:1 work, then by all means. Hub motor = simple solution. I think my next build will be a hub motor...
    EDITED TO ADD: The early Guzzi shaft drive isn't bad for torque handling, but the later one does better. I think it would survive under an electric conversion given the infernal combustion engines which they backed to that shaft drive...
    '10 Zero S project
    687
    I think ZERO is 4.2:1 I looked into this too with a Suzuki Savage.
    Feb 2018
    I have never had a shaft drive motorcycle but from pictures online it looks as if the shaft drive requires a special hub. am I wrong? Aside from that I cannot find any websites that sell hub motors for motorcycles that doesnt look fake.
    319
    This is the place you are looking for: http://www.enertrac.net/product.php
    Quote Originally Posted by halu View Post
