Results 1 to 8 of 8
Thread: Need Advice
    Junior Member Jessa's Avatar
    Apr 2018
    California
    Need Advice
    Hello everyone, Have any of you experienced having a helmet that fogs up while driving at a cold weather? What do you do to stop your helmet from fogging because I'm having the same problem with my helmet. I hope you can give me some insight about this. Thanks!
  2. Likes N/A liked this post
    May 2018
    I used to ride through the winter. I was never able to completely eliminate fogging but I had limited success with using some form of breath deflector. In the winter that was usually my scarf that I wrapped around my mouth and nose, then down around my neck and into my jacket. Not sure how effective that will be with a full-face helmet though.
    2,781
    I have that problem all the time during cold, wet, or foggy weather. There are lots of anti-fog chemicals on the market that will help some. But they do need to be reapplied before each ride. I also have one helmet with the Pin-Lock face shield system. But that requires a helmet face shield that comes with the pins that the Pin-Lock attaches to, which typically is on the more expensive helmet brands. Plus replacement Pin-Lock inserts are not cheap!
    Since I have been dealing with this problem for 55 years now, I continue to try different solutions. Just about any of these solutions, including a breath deflector, works to a certain extent, but what works the best for me is to crack the face shield slightly and put up with a cold breeze on the face - which can be mitigated with a scarf, or something similar. Of course, once finding a solution to defogging the face shield, if you wear glasses you end up having to keep them from fogging.
    Feb 2017
    Chicago, IL
    32
    This may not work for you, but I have a motocross-style helmet- it's full face but I have to wear goggles. I have not had issues with fogging even at cold temps but I haven't ridden all winter (yet). What about a reusable dusk mask like people wear in Asia? If it forms a good seal that might work.
    258
    Just buy a full face lid with a pin-lock visor and be done with it. Only way to go, no more fogging regardless what the weather.
    Apr 2016
    10
    maybe try applying hydrophillic coating on the inside of the visor? fog occurs when tiny beads of water form on a hydrophobic surface. with a hydrophilic surface, the water coat the visor evenly in a film, instead of droplets (ie. no fog)
    713
    Quote Originally Posted by Spectastic View Post
    That stuff is a useless waste of $$$$ in my experience. Helmets are so expensive these days, they should have solar powered ventilation.
    Jun 2018
    4
    Always had this issue, think the only way i found was good cleaning and good ventilation. Downside was having a cold face.
    Could always try using a snorkel?
