Results 1 to 7 of 7
Thread: Now available: sprockets, Clearview display and Domino throttle
    2,668
    In addition to selling the Sevcon Gen 4 Size 6 controllers, ME1507/ME1616/ME1304 motors and other accessories, I'm happy to announce that we're selling 11T hardened steel sprockets for 7/8" and 1-1/8" shafts for 428 and 520 chain (respectively) made bu Amp Sprockets. We're also selling the Sevcon Clearview display to display parameters from the Sevcon Gen 4 controllers. I also worked to get a batch of Domino throttles for people!
    Take a look and let me know if there are questions!
    Domino:
    http://www.emf-power.com/product/domino-throttle-used/
    Clearview:
    http://www.emf-power.com/product/clearview-display/
    11T 520 Sprocket for 1-1/8″ Shaft:
    http://www.emf-power.com/product/11t...r-1-1-8-shaft/
    11T 428 Sprocket for 7/8″ Shaft:
    http://www.emf-power.com/product/11t...for-7-8-shaft/
  2. Likes EVcycle, Nicman liked this post
    Senior Member Nicman's Avatar
    Jackonsville, FL
    116
    Frodus,
    The gen4 size 6, can it be adjusted to accept 128 v DC?
    120% of 116 is about 140 and I read that they are able to operate from 70%-120% of nominal voltage.
    I have a line on some 10C NMC that come in 64v modules.
    Thanks
    2,668
    Frodus,
    Thanks
    Is this the one you bought from me? The ones I sell go to 120V. Above that, they go into shutdown and do not turn on.
    Jackonsville, FL
    116
    No, I didn't buy one from you (yet.) Just wondering how much wiggle room the controller has for adjustments. Like with the data cable CAN bus and all that magic.
    The nominal voltage for my pack is 111v but it maxes out at 130v.
    Just trying to get everything I can out of the pack, motor and controller set-up.
    2,668
    120V is the absolute max on this controller. It can withstand higher, but it will not function above 120V. i.e. it won't work.
    Reduce voltage to below 120V and you should be OK.
  7. Likes EVcycle liked this post
  8. #6
    Jackonsville, FL
    116
    Any idea if you will be getting the Sevcon Gen5 size 7?
    http://www.sevcon.com/products/high-...llers/gen5-s7/
  10. #7
    2,668
    No plans so far. There is a large inventory with my supplier of these Size 6 controllers and I'll be working to sell those before considering going to anything else. It requires a direct relationship with Sevcon and a large number of sales numbers per year. No one else that I've seen (EV Vendors) are selling those either.
