Likes Likes:  5
Results 1 to 10 of 12
Thread: Requesting help with Buss
    823
    The only way I can fit this volume of batteries into what little space I have available is to separate them into 3 groups of 8 in series for a total of 24 in series. There is no other way to fit them... I've thought of and tried every possible way I could imagine with Styrofoam mock-ups.
    My question has to do with the buss between the 3 groups... Do you more experienced builders think I can safely use 2-0 cable to buss the 3 bundles? I will need to make two of them. I plan on keeping the cables as short as possible, and of equal lengths. It's the only way I can think of to connect the 3 compartments.
    241
    I don't see why that should be a problem. I have a cable between two stacks of Leaf modules in my bike, and that hasn't been a problem. I just used the same wire as I did for the rest of the high-power wiring. It'll be carrying the same current unless you're doing multiple parallel banks.
    823
    I was thinking that also. I wonder if I could get away with using 4-0 cable. Maybe overkill with 2-0 is a good thing. I think I will tape a temp sensor on to these bus cables to monitor how hot they get.
    2,676
    What cells are you using and how are you putting them in series/parallel?
    Jul 2018
    How many amps are you pushing through it continuously? And what's your longest cable run? I'm running 50mm2 (1/0) cable for 550 amps peak (30 seconds) and about 200amps continuous. The cable gauge doesn't need to be crazy, as long as your not pushing it constantly and your cable runs are within reason (1-2 meters), also what's your voltage drop tolerance?
    823
    Travis,
    I was able to work out a deal with Patrick (aka theFREElaker on this forum) for these never used cells:
    24 in series, no parallel cells.
    Upperfoot, the longest cables will be to the controller from the battery pack at less than 14"... probably around 10", and as far as sag and max amps, I'm clueless, maybe Travis can provide some input answering those questions. I don't know what this set up (Sevcon gen4 size6 and ME1616) will draw. The length of bus cable between the 3 groups will be approximately 6". I have 2-0 and 4-0 cable readily available.
    Jul 2018
    Funnily enough I have the same Motor / Controller setup as you. I'll be maxing my Sevcon at 660 amps with 24 of these https://hobbyking.com/en_us/turnigy-...ck-w-xt90.html (6 parallel x 4 series) for 48Ah at 100v. I use this for the voltage drop so with your criteria using 2/0 it will be https://www.calculator.net/voltage-d...=660&x=88&y=18
    2,676
    Kokams are awesome cells!
    I'd just make some clamps for the series connections, fold the tabs over and clamp. Might do some searching on the interwebs for kokam packs at DIYElectriccar.com.
  11. Likes Stevo liked this post
  12. #9
    Jul 2018
    This is an interesting read about Kokam pouches http://www.metricmind.com/audi/14-battery.htm
  13. Likes Stevo liked this post
  14. #10
    823
    I made enough room at the top to keep the tabs unfolded, then I can put a thin sheet of silicone rubber in between each series clamp to isolate them. Since the box is Al, it should absorb the heat fairly well except that it will be lined with silicone foam rubber sheet. The 6 outside cells will probably be the coolest, maybe. I'm not sure how hot the batteries will get all insulated in foam rubber for shock protection. It is a dirtbike after all, that they're going in. The lids will be fab'ed with some of the acrylic box Patrick included. It's a shame to cut the boxes up. I know he put a lot of hours work into them. But they will make nice tops. I'm planning on incorporating the Cycle Analyst's shunt and the LEV-200 into the Battery box. And the cables from the Sevcon will bolt onto the battery box lids, so that I wont have to ever unbolt the cables off the Sevcon. It will be difficult to get a wrench to.
