0
85 Vespa project - great starter, awesome daily driver
2k reserve on eBay Thru July 13....
https://m.ebay.com/itm/1985-Other-Ma...&soutkn=g5LEAi via @eBay
Highlights
Dual disc brakes
Rear hub motor
Headway battery pack
Hidden electric drivetrain, stealth setup
Full chrome package
Many custom parts -swingarm, speedo housing, battery trays under stock fenders, kill switch, wire looms
History
I bought this bike from a well known importer of Headway battery cells who did most of the work to this bike in Washington state, USA. He did some fantastic body work, paint work and electrical to get this bike to 90%. Most importantly, he had a custom rear swing arm made for this. He also had a custom speedo and aluminum collar made for the cockpit. German front end brake also added. The drivetrain components come from Kelly (high voltage controller, 72v), and a 6kw rear hub motor.
The bike
The bike also has a test pack of headway cells ready to go. Jim fabricated some battery cases to fit under the rear cowls. Super slick. It has been wired to keep everything super hidden. Reviving the stock motor gives tons of room for controller and other gear under the seat. This bike looks completely stock from the outside. On top of that, it comes with a full suite of chrome body parts - front rack, rear rack, white wall spare, chrome hub.
Getting it finished
Depending on your skill level, this bike requires a few hours (experienced with electric bikes or motorcycles) to a few days (for rookies who are handy with basic electronics) to get running on the test pack, which should provide 10-15 miles. I will provide two hours of online a and a for any buyer to share what I learned about the bike while I had it.
Upgrades
After getting this going, if it Isn’t fast enough for you, I would recommend upgrading to the new EnerTrac water-cooled hub motor. That and some 18650 cells would make this an epic electric bike.
Why I’m selling
I bought this to make it my waterproof daily driver. Parking and other constraints at work mean I need a different option that’s legally a bicycle, not a tagged motorcycle.
I spent five years looking for the right electric Vespa, and this is still one of the best in the US. If you want to put in a little work, this could be an amazing solution for you.
Clear title
Is in previous owner’s name to be signed over to new owner.
This is a local pickup listing only, but I will work with any shipper you arrange for pick up and transport from New Orleans, LA.
Matt Candler
Night Shift Bikes
http://nightshiftbikes.com
Here’s Jim’s original build thread: http://elmoto.net/showthread.php?t=2...Electric+Vespa
Reserve is $2k
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
