Likes Likes:  13
Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 87
Thread: 1980 Kawasaki 440 LTD 8kW conversion
    141
    Quote Originally Posted by Functional Artist View Post
    Ya, I know. I've done a lot of work on go karts & jack shafts are used a lot.
    I just working with technology & terms that I was used to & also parts that I already had, to work with.
    I was thinkin' strength. Most idlers, that I knew of were for light duty situations like routing belts on car engines.
    I figured this big motor, motivating a full size motorcycle, would apply much more pressure/force.
    I guess you could call it a DIY super HD idler/(1) sprocket jackshaft.
    I can't put anything above the swing arm, that where the motor is going to be mounted (it fills the whole space)
    It looks like this set up will but, I appreciate the input, stay tuned
    Here is a video with more info
    https://www.youtube.com/watch?v=P0ReyyFYkKk&t=190s
    It seems to me you're going to a lot of work,expense, and an extra 5# of weight, when there is an easier, cheaper, and lighter solution. An idler on the slack side of a chain or belt drive is typically lightly loaded when compared to the other bearings and sprockets in the system. Regenerative braking would put an intermittent somewhat heavier load on the idler- but probably well within its load capacity.
    The location for the idler sprocket I'm referring to is far away from the motor location, close to the rear sprocket, on top of the swing arm.
    IP
    Senior Member Functional Artist's Avatar
    Aug 2018
    104
    I'm not following you.
    On top of the swing arm, between the motor (drive sprocket) & wheel (driven sprocket) is the "heavy load" drive side & not where an idler is needed
    I needed an "idler" sprocket down below the motor, on the "slack" side, to help route the chain around the swing arm
    The motor rotating clockwise pulls on the sprocket of the rear wheel, via the chain, making it turn clockwise too
    ...on the "slack" side, the chain comes down off of the motor sprocket to the jack shaft sprocket "idler"
    ...then, wraps around the "idler" sprocket, clearing the swing arm & goes back to the sprocket on the rear wheel completing "the circuit"
    IP
    141
    I think you meant to write counterclockwise. Put all of the chain above the SW, between the sprockets. Put the idler sprocket in a fabricated bracket on top of the SW, close to the rear sprocket, below the lower, slack chain. The one clearance issue may be where the chain passes over the idler sprocket, past the inside of the SW tube, to the rear sprocket. Some minimal flattening of the inside of the SW tube might create enough clearance, as I wrote before, or move the sprockets inboard slightly.
    IP
    Aug 2018
    104
    Yes, counterclockwise
    A feature of "this" concept is that the gear ratio can be easily changed.
    ...the motor & "idler" both have a 3/4" shaft with a 3/36" key
    I am using a 10T sprocket on the motor, a 13T sprocket on the "idler" & a 54T sprocket on the rear wheel for a 5.4:1 gear ratio
    So, by simply swapping the motors 10T sprocket with the "idler" 13T sprocket the gear ratio would change to ~4.1 gear ratio
    …& the chain length & tension would not change or have to be adjusted
    How well this motor will motivate all of the weight of the motorcycle & the operator & at what gear ratio is questionable
    ...this concept gives me options
    IP
    141
    I think you meant to write 3/16" key. Interesting rationalization for an overweight and overwrought design.
    IP
    Aug 2018
    104
    Yes again, the key is 3/16"
    ...typin' too fast
    Interesting description of my DIY idea though
    Next, I had to make an "extension shelf" to help support the motor
    https://www.youtube.com/watch?v=C4zEj0xQ9g0
    & here's another
    https://www.youtube.com/watch?v=CbBYPVDzMcU
    IP
    Aug 2018
    104
    This video may help to explain this jack shaft/idler concept & placement a bit better
    https://www.youtube.com/watch?v=P3EOoFsOFu4&t=4s
    IP
    141
    So, how is this design working out for you?
    IP
  9. Likes T Rush liked this post
  10. #19
    Aug 2018
    104
    Functional Art!
    Installing the motor
    https://www.youtube.com/watch?v=WFKgGyDU0IY
    IP
  11. #20
    Senior Member T Rush's Avatar
    Mar 2018
    Iowa City, IA. USA
    122
    ok, now I see what(why) you are doing....unless you explained this in another video; but with your motor placement, the chain can't directly drive the rear sprocket as it would of hit the swing-arm where the chain rounds the bottom of the sprocket angling to the motor....so with the jackshaft the chain can stay under the swing-arm until it has clearance to run straight up
    unique solution...and it all works because the motor sprocket, idle sprocket, and drive sprocket are mounted to the swing-arm
    I thought about a similar idea for a motor in that area of the frame; with two idle sprockets(locked together or keyed on the same jackshaft) at the swing-arm pivot point, then using two chains(one on the motor, other on the rear sprocket) to the idler sprockets....as the swing-arm pivot point sprockets stay relatively stationary to both drive or motor sprockets, tho the distance directly between them doesnt....and the two idle sprockets can have different numbers of teeth to step down the gearing
    ...so I couldn't quite fully imagine how your chain wouldn't go slack(and if the idle sprocket was to take up that slack?) , and why you couldn't just directly drive the rear sprocket from the motor; until I saw that last video, but I get it now
    [edit] oh, I just noticed that last video is a year old and saw videos of this project completed, err or almost....but why does it still have the exhaust pipes on it? [/edit]
    IP
