Likes Likes:  13
Page 1 of 9 123 ... LastLast
Results 1 to 10 of 87
Thread: 1980 Kawasaki 440 LTD 8kW conversion
    Banned
    Aug 2018
    114
    Last summer, I picked up a nice 1980 Kawasaki 440 LTD with a seized engine for $100.00
    The guy actually wanted $250.00 because, he said, the carbs were "rebuilt" & worth $100.00 each
    So, I said, "will ya take $100.00 CASH & you can keep them carbs, maybe sell them on eBay"
    I took 'er home, stripped 'er all down & cleaned 'er up
    Here is the intro video
    https://www.youtube.com/watch?v=bkLXnjOEB7Q
    IP
    Banned
    Aug 2018
    114
    I just tried to attach a picture & again it said "file too large"
    SAM_4519.JPG 3.40 MB
    Here is a video with lots of information on dismantling the bike.
    https://www.youtube.com/watch?v=M1IUs5TG9HU
    IP
    731
    The pics need to be smaller files because I think of bandwidth. Try to lower the MB size until you find the size that works. You might need to use photo edit tool in your programs. You know, for flipping or changing contrast and brightness or cropping your pics.
    IP
    Banned
    Aug 2018
    114
    Figuring out where to put the motor was next
    Here is a video discussing the available options
    https://www.youtube.com/watch?v=Escb_E891e8
    I "finally" got a pic to upload
    ...had to edit it twice
    ...but, it's just a little fella
    How do you add pics so their big & visible?
    ...not a little thing that ya have to click on to see
    IP
    Banned
    Aug 2018
    114
    Cool Alternative motor placement idea
    I think, I can stuff the motor "up in the pocket"
    ...mounted right onto the trailing arm
    This way the motor & the rear wheel will move as one
    & there will be a heck of a lot more room, inside of the frame, for batteries & electrical components
    So, now the motor will go where the battery used to be
    & the batteries will go where the engine used to be
    https://www.youtube.com/watch?v=zUfhil1jfqE
    IP
  6. Likes Spoonman liked this post
    731
    Hmmm... Are you using "the Gallery" to upload your pics into? From there, you can copy the link to your pics and they will show up large on your thread. The Gallery is cool too because you can copy a link and post pics on other forums without having to upload the pic again on that forum.
    IP
    Banned
    Aug 2018
    114
    Decision time
    The motorcycle (Kawasaki) uses "big 'ol" #50 chain (5/8" pin to pin) & sprockets
    My 8kW motor has a 10 tooth sprocket for #40 chain (1/2" pin to pin)
    ...I have a 54 tooth driven sprocket (that I can use on the rear wheel)
    ...& I have ~10' of #40 chain too
    #40 chain is also a bit lighter
    So, we'll go with that, #40 is the winner
    Then, I removed the rear wheel assembly, to switch the sprocket from a 45 tooth for a #50 chain to a 54 tooth for a #40 chain
    Before instillation, I had to do some DIY machine work, on the driven sprocket to make it "fit" onto the Kawasaki rear wheel
    Here is a video with more info
    https://www.youtube.com/watch?v=boTUgLzOe00
    IP
    Banned
    Aug 2018
    114
    We kinda have a plan
    ...now, let's see if we can make it work
    Going to have to
    ...build a motor mount extension shelf
    ...then, get the motor aligned & mounted
    …& add a couple of bearings & an "idler pulley/gear" to help route the chain
    https://www.youtube.com/watch?v=QvE4Ir8pxPk&t=5s
    IP
    143
    Technically speaking, what you call a jack shaft is actually an idler shaft or just an idler. A better placement for the idler would be above the swing arm to get the maximum chain wrap on the sprockets. This decreasing wear, chain noise, and reduces the possibility of the chain slipping.
    Chain idler sprockets are available. They are compact, easy to mount, and cheap: https://www.amazon.com/Idler-Sprocke.../dp/B00O57YAL4 They can be mounted with a single shear bolt on a heavy bracket or with a double shear bolt between 2 lighter brackets for more strength. The idler sprocket would have to be mounted well back on the swing arm to allow the chain to clear the inside of the swing arm. Some bikes may not have enough clearance in this area. The front and rear sprockets may have to be moved in to create more clearance. Or, the swing arm flattened slightly on the inside near the rear sprocket teeth.
    IP
    Banned
    Aug 2018
    114
    Ya, I know. I've done a lot of work on go karts & jack shafts are used a lot.
    I just working with technology & terms that I was used to & also parts that I already had, to work with.
    I was thinkin' strength. Most idlers, that I knew of were for light duty situations like routing belts on car engines.
    I figured this big motor, motivating a full size motorcycle, would apply much more pressure/force.
    I guess you could call it a DIY super HD idler/(1) sprocket jackshaft.
    I can't put anything above the swing arm, that where the motor is going to be mounted (it fills the whole space)
    It looks like this set up will but, I appreciate the input, stay tuned
    https://www.youtube.com/watch?v=P0ReyyFYkKk&t=190s
    IP
