Results 1 to 10 of 13
Thread: Sun 300-1774
    Senior Member Nicman's Avatar
    Jackonsville, FL
    116
    Sun 300-1774
    Hey guys
    I just bought two of these power supplies for only 25 bucks each.
    They run in 220v but gets stepped down to 48v and 67.5amps DC. There is an adjustable pot up to 12 extra volts.
    I plan on putting two in series to to get
    117.6 v and limit the current to 42 amps.
    I'm not sure about the pin connector on the back but I think it's worth the risk to get s 3kw charger for $50 total.
    I've seen the HP ESP-120 used as a off board charger and plan on doing something similar with these.
    What do you think? Any clues about the pin connector? I'd like to hook this up to a J1772 if possible.
    2,659
    I had some that used a different connector, but something along those lines. They may need some of them connected together to enable the power supply. Also, it looks like that's where it gets it's AC. Might see if you can solder or connect to the pins on the inside of the supply instead.
  3. Likes Spaceweasel liked this post
    771
    The price is right for sure. Keep us posted on this!
    Jackonsville, FL
    116
    These two just arrived. I don't have time to look at them but I will this weekend.
    Also, I can't do anything until I get 220 in the garage. Either way I win. If these can be slightly adjusted to charge to ~117.6V or maybe even adjustable voltage that'd be a huge win. Or I can run some 48v packs separately charged then connect them in series when not charging. Too many ideas floating around in here.
    771
    Not a bad idea that I've considered more than once. Having multiple packs is great cause you'd always have a full tank waiting for you in the garage. What's stopping me on that idea is why spend the money on twice the battery? What cells are you using?
    Do you have software that controls the charger? My Meanwells have a voltage output pot easily accessed at the back of their case. Yours looks like the v output adjustment is more challenging unless one of those screws on the exposed green circuit board is the v pot (or the lone phillips head screw in the corner?). Great deal on the price... nice find. Congrats. Looking forward to watching your build progress!
    Sep 2018
    Inside pictures
    https://drive.google.com/file/d/1yyf...w?usp=drivesdk
    https://drive.google.com/file/d/1VOV...w?usp=drivesdk
    https://drive.google.com/file/d/1pM5...w?usp=drivesdk
    Jackonsville, FL
    116
    Sun 3000-1774
    Opened up the PS today to get a better idea of what needs to be done to get 220V (which is now in my garage) to the PS input.
    I see two grounds to the frame here.
    and a connector from the pcb that says Vo In which I believe is voltage sensing since they are ~22awg wire (purple, red, blue and grey)
    I'm looking for a female connector and getting quotes but I may have to do what Frodus suggested and take off the male connector in order to solder directly to the existing wires. Still trying to figure out which is which so I don't ruin one in the process.
    287
    Just an FYI in case you're not already aware and in case any future thread visitors decide to try this with any old PSU.
    Those look like server or NAS PSU's - so there's a very good chance that those DC outputs are referenced to ground and are not floating. You'll have to confirm that they are indeed floating outputs before you attempt to connect them in series. If they aren't floating then you'll need to establish whether or not the reference is being provided by a cable which you can cut, or if it's inherent elsewhere in the design (in which case it's unlikely you'll be able to anything without a significant amount of effort). If the outputs aren't floating then connecting them in series will amount to shorting the output of the first one in the series straight to its own common terminal.
  10. Likes Nicman liked this post
    Jackonsville, FL
    116
    Hey guys!
    So after sitting for close to 8 months I got the supplies out and really tore them open.
    I wired up a couple of leads and they turn on, but there is no output voltage.
    I'll try to see if it needs to sense a load in order to charge.
    Any ideas without having to spend a ton on more leaf batteries?
    Thanks!
    2,659
    They may not regulate the output unless hooked to a load. Can you test them with a load?
