Likes Likes:  14
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: KwSAKI Mk1 (Ex 500)
    Feb 2018
    North East, US
    22
    UPDATE 2: I got the motor turning last night! Super close to a test ride.
  2. Likes Ted Dillard, Mandres, Stevo liked this post
  3. #22
    Feb 2018
    North East, US
    22
    UPDATE 3:
    Wired Thunderstruck BMS, Thunderstruck EVCC, Wired charger. Way easier to setup then I thought.
    Diagnostics on my pack show all cells very close to each other volt wise (.002 average voltage deviation).
    Installed new rear damper and chain.
    Up next:
    Wire J1772 plug (so I can finally charge my batteries, dont worry they are still 4v a cell)
    Chain guard
    After I finally get a test ride under my belt. I am going to do a deep dive (lots of pictures) on each module or system in the bike and how it was setup / wired / assembled.
    Let me know what you think,
    -Aggrc
  4. Likes Nicman liked this post
  5. #23
    Oct 2018
    7
    Hope it's coming along well. I'm very interested in reading more about the build and the different systems. Have you run into any big problems?
  6. #24
    Feb 2018
    North East, US
    22
    UPDATE 4:
    The riding season is on its way up here in the northeast, seems like a great time for an update!
    J1772 DONE, very nice set up with the thunderstruck EVCC doing its magic and working well with thunderstruck BMC system.
    Up next is getting the batteries covered up (carbon fiber panels for each side and front of pack), also making a chain guard, right now I have a massive piece of plastic bolted to the side of the bike to protect my foot from being eaten by the front sprocket.
    Issues, I have a 500W DC/DC converter that has been giving me some troubles. Only likes to kick out 12v volts if the plug on the unit is held just so. I thought it was my wiring to the plug but I bench tested the DC/DC and found the same weird behavior. Then to top it off I dropped the darn thing and bust the plug right off. Whoops. So now I am looking for a 300W replacement.
    Impressions of the bike:
    Ill be honest not blown away by the off the line performance. I am taking a look at the throttle mapping to see if I can get more get up and go out of it. Any advice here is greatly appreciated.
    Currently the bike does around 60 mph flat out, so I am looking to bump the rpm max from 4k to 6k. If I remember the spec sheet thats reasonable for the ME1507.
    It does burnouts like a champ, which brings me to my last point. During my last burnout I got a cell voltage low. The pack was fully charged and balanced so I am worried I have a cell in the pack thats on its way out.
    Tell me what you want to hear more about, as always Ill try and add some photos.
  7. #25
    Feb 2018
    North East, US
    22
    rear fairing removed to show more of the bits
  8. #26
    748
    I too went with the Thunderstruck BMS, but I didn't get the charger controller...
    The BMS is powered up by an isolated 12v dc-dc source so there should be no problems with it... this allows for the BMS to be powered on when the bike is charging and off, as well as when the bike is being operated.
    Are you utilizing either of the error loop circuits? I was thinking of using one of the loops to control a relay for the charger power supply, and turn off the charger when the first cell hits 4.1 volts. I was wondering if you configured the BMS for that function and if it worked well. I don't want the charger to keep cycling power on and off when the top cell fluctuates between 4.1 and <4.1 as the charger kicks off/on.
  9. #27
    Feb 2018
    North East, US
    22
    I'm not using the either of loops but that is an interesting application for them. I dont see a reason why you couldnt do that.
