Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Hub motor repair
    Hub motor repair
    I just started tearing down the hub motor on the X-Treme scooter I salvaged, here's the first phase of the repair. I say repair with hope, and pure thoughts. Unicorns too, I have unicorns.
    I'm lazy right now, so here are a few teaser photos. There are more on the post, and I might update this post with more as they come.
    http://evmc2.wordpress.com/2010/10/1...e-a-hub-motor/
    Detroit, MI.
    275
    Is that a PM Motor? What is wrong with it? Can you borrow an inverter to test it out?
    Yes, the wires feeding into it are frayed, and he tried to solder them but they were exposed. I'm going to start by remaking the wires, I'm not sure how to test the Hall sensors, but there's an Instructable post that talks about it.
    http://www.instructables.com/id/Elec...ace-a-Hall-ef/
    Oh. I see there's no real way to test them... I guess it's easier to replace all three.
    What's an inverter?
    Moderator
    Isle of Man
    365
    Dead easy to test them Ted. Wire a PP3 9V battery across the Red/Blk (pos/neg) and with your DC volt meter measure across Blu/Blk, Yel/Blk and Grn/Blk when you waggle a fridge magnet or whatever over the relevant sensor. The reading should go from high to low or low to high depending on the polarity of the sensor. If you don't see a change, they may be 'current output' devices. You can check these by putting a resistor (1K to 47K range) in series with your meter probes. Set your meter to DC milliamps and probe between Blu/Red, Yel/Red and Grn/Red when waggling.
    Caveat, some sensors only good for 5V so PP3 (9V) might be too much, but unlikely.
    Also, can you check with a meter the value of those resistors. I see they say 470, but in normal surface mount world that means 47 ohms i.e. 47 and no zeros. Seems very low to me, I'd expect 471 at least i.e. 47 and one zero .. 470 ohms.
    Rob
    how do you know this ****? lol!
    wait, I should ask, how the **** do you know this ****?
    Senior Member harlan's Avatar
    Hollywood, CA
    250
    Follow harlan On Twitter Add harlan on Facebook
    Visit harlan's Youtube Channel
    Hacked my magura throttle with one of those hall effect sensors. Throttle response is much smoother than with the POS trimmer that it had before.
    Cleveland, OH
    487
    Because he's Rob and you're not......
    Quote Originally Posted by BaldBruce View Post
    I wanna be Rob when I grow up.
    Moderator
    Isle of Man
    365
    It's my job Ted, it's how I eat.
    If I was paid for my photography Knowledge I'd be on elsoupkitchen.net
    Harlan, that looks like a cool mod. Any chance you could detail it in a thread?
    Rob
