It's been a while but I finally have time to sit down and edit some pics and write up the new and improved v3.3!
What's new?
1) modified frame/batt box mounts
2) newly designed and much lighter motor mount plate
3) newly designed BattBox
4) addition of Thunderstruck BMS
5) newly designed dashboard with camera hole cutout for my phone's camera
I changed the battery box using Harbor Freight pelican box knock-offs. I was hoping to add two more cells to 26, but ended up keeping it at 24, simply because the Thunderstruck BMS allows 24 cells. To add more cells was another expensive module, which would allow 12 more cells. Not really worth the expense just to add 2 more cells. I'm sure the boxes aren't waterproof, but a bead of silicone should make them fairly weather proof.
They don't look too ridiculous IMHO. They are big enough to squeeze in all of the electrical components (main fuse, contactor, hall sensor, Cycle Analyst shunt) along with the cells. Deciding where to put all of the cable/wire pass-throughs was a challenge. I also added some frame sliders to the design, to help protect the battboxes when I crash
I was also hoping to lighten up the bike a bit... It now weighs in at 419.6 lbs (190.3 kg) ... still too heavy!
I wasn't using a BMS before because there weren't any affordable options yet. I was manually balancing the cells, and this mod is truly worth every penny to simplify life!! For under $500, the Thunderstruck BMS is affordable and works very well. I splurged and bought the touch screen display too, although it isn't necessary for the BMS to operate. I'm quite happy with this new addition. The display makes it super easy to monitor each cell during the charging process. I highly recommend this product.
Now, the PICTURES!!
First, the battery box...
The center box bolts to the frame slightly differently then before. The motor mount bolts directly to this box also. It's a very rigid design. I don't feel any frame flex while riding. The coolant pump is also attached to it, seen just under the front fender.
Here you can see the new motor mount plate and the right side battbox holding plate, mounted without the battbox attached.
Here is how the pelican box knock-offs look when they are attached to the mounting plates.
Installing the Rt side battbox.
These pics show how the contactor, hall sensor and main fuse is securely stuffed into the box, using dense foam rubber (3 lb density closed cell foam).
This is the the Rt side box, the pack + side.
I constructed the the pack with thin rubber sheet in between each cell, and 1/8" thick silicone sheet between each set of electrodes. I'm confident there will be no arcing between cell pairs. There is some debate regarding separation of cells with metal sheet to contain a "run away" event.
My pack is divided into 3 compartments, 9 cells in each side box, and 6 cells in the center box. I conferred with Patrick, who I bought the cells from (theFREElaker here on this forum) and we both agreed that the extra complexity wasn't necessary. Time will tell![]()
