Results 1 to 10 of 16
Thread: Aprilia RS125 2-STROKE conversion
    Feb 2020
    4
    Hi to all of you - I am new to this blog. Busy converting an Aprilia RS125 2-STROKE to electric. Have slung a QS Motor 34kW hub-mounted motor in the swingarm. Beast of a motor but I am struggling to find a matching controller. Burnt out 2 Kelly KLS 8080I 400A controllers already. Both failed to cut back on high temperature and / or shut down completely on over temperature. I now have an APT96600 controller. Anybody tried this combo? Help
    Mar 2020
    Bundaberg , Australia
    16
    That's a huge amount of torque for a frame designed for muich less.
    One of the greatest handling road frames EVER. Might be worth de-powering a little, though itwould be fun to ride it like it is.
    I reckon an RS250 running chassis would be a better match for that much torque.
    Would love to see a pic or better yet a track video!!!
  3. Likes Spoonman liked this post
    99
    I think that is a typo, it's a 4kw rated motor, probably does 12-14kw max with the new controller.
    Cheers
    Tyler
    Feb 2020
    4
    It's a QS Motor 14kW (nominal) and 34kW (maximum) hub-mounted motor. 43kg. 350Nm of torque.
    Mar 2020
    16
    Take one of the best handling motorcycles on Earth and add 43kg to the back wheel of a bike that weighs not much over 100kg total. Unsprung to sprung mass is not exactly ideal. Rear suspension will be completely overwhelmed.
    911
    Can the rear shock be resprung and dampened? I checked my suspension go to RaceTech and they only have kits for RS250
    Mar 2020
    16
    Definitely can be resuspended. You need a friendly experimental and knowlegeable suspension person hands on.
    The big problem with suspending it properly is the crazy unusual weight distributions
    . You have a crazy light chassis and swingarm, mated to a crazy heavy wheel, with massive torque across the rev range. It is completely out of the realms of the experience of almost everybody. I am NOT saying it can't be done, just that it is going to take a VERY intelligent and clean slate approach. Pretty much every chassis and suspension parameter will be wrong for optimium handling.
    Good luck. It is the sort of problem I would love to be involved in solving and ,I bet, so would any creative suspension person .
    My approach would be a mid engine but I would love to see an elegant solution to the rear hub motor problem.
    911
    Finding the right spring is key and will take some experimenting ($$$)
    Heavier oil and reshim the dampening and rebound shim stacks translates into more time experimenting.
    Hopefully you can get it close in a few shock rebuilds. It would be an expensive project to get it dialed in right.
    Mar 2020
    16
    Spring rate is the least of the problem. 43kg+ of unsprung weight on the end of a swingarm, will require really custom damping curve and complex SSV. Even on a flat road, if you get brake chatter, the damper will be severly stressed.
    Getting the CoG anywhere near the pendulum axis will be a feat in itself.
    911
    The shim stacks will need to be redone like I said. Heavier oil and reshimming the valves will do the trick, but it will take some experimenting and that means shock rebuilds. Lots of time and nitrogen refills. It would be a challenge and expensive for sure. That's why I chose to stay away from hub motors.
    With that said, there are still some advantages to hub motors that are compelling. I think they are perfect for smallish scooter type builds,but that's just my 2 cents of opinion.
