Likes Likes:  9
Results 21 to 30 of 39
Thread: 1979 XS750 electric conversion
    Jun 2020
    30
    My motor came in today!
    Jun 2020
    30
    It is a lot bigger than I expected.
    Dunno why. I knew it was 17 inches, and I mocked up the dimensions, but seeing it in person is... wow.
    Jun 2020
    30
  4. Likes Spoonman liked this post
  5. #24
    Jun 2020
    30
    This week, I built a temporary stand for the motor out of wood, and hooked up the controller and a small 48v battery I built for another project to test everything:
  6. #25
    Jun 2020
    30
    I sized up the motor with the swingarm I got off the Fazer, but it looks like I will have to do some modifications... Any suggestions?IMG_20200919_160632.jpg
  7. #26
    344
    Yeesh - that's a good sized gap there alright.
    Are those studs integrated?
    I don't see that arm squeezing down enough to make the studs work. If you could change them out then you could use heavy spacers to take up the gap - it wouldn't be pretty bit I expect it would serve well enough and I expect you'll need to do something to that effect in any case to maintain cable clearance.
    To do it right though you're looking a refabrication IMO. Retain the pivot and have some new box section with the right dimensions welded up with some appropriate relief for the cables.
  8. #27
    Aug 2020
    Can you please provide different wheel and axle dimensions so others could have more detailed information? Thanks.
  9. #28
    Jun 2020
    30
    Quote Originally Posted by dnsukraine View Post
    Here is an image generated from the mechanical drawing. Hope that is what you were asking for?
  10. #29
    Jun 2020
    30
    There's not actually a lot of gap. It's about the width of the torque arm on either side.
    I ended up modeling an adapter that I plan to slide over the axle on either side and then into the swingarm.
    I plan to make it out of 6061 T6 aluminum, so I left a pocket for the hardened steel torque arms it came with.
  11. #30
    Jun 2020
    30
    -snip-
    accidental double post
