Results 1 to 10 of 21
Thread: MotoCzysz D1G1TAL DR1VE D1 Revealed!!!
    Jul 2007
    San Diego, California
    428
    Follow ElMotoMike On Twitter Add ElMotoMike on Facebook Add ElMotoMike on MySpace
    Add ElMotoMike on Linkedin Visit ElMotoMike's Youtube Channel
    via press release
    Nov 10, 2010, Portland, OR- MotoCzysz unveiled the world’s first fully integrated electric drive system- the D1g1gital Dr1ve D1- at the EVS25 show in Shenzhen China on November 5th 2010. Targeted to power the next generation electric vehicles and series hybrids, the D1g1tal Dr1ve is slated for delivery in May of 2011, for under $8999.
    The D1g1tal Dr1ve D1 is a compact, advanced drive system that incorporates motor, inverter, oil pump, gear reduction and differential, all housed in a light-weight aluminum case. The complete integration of components makes the D1g1tal Dr1ve a true “plug and play” alternative, dramatically reducing the typical design time and costs associated with electric vehicles.
    The integrated drive technology housed in the D1g1tal Dr1ve powered the MotoCzysz E1pc motorcycle to two race wins and two track records in 2010. The E1pc dominated the field at the Isle of Mann TT, winning by over two minutes ahead of the closest competitor; this same technology also powered the MotoCzysz E1pc to over 163mph at Bonneville.
    By combining innovative, race-proven technology with the power and reliability of the Remy Motors HVH250, the D1g1tal Dr1ve becomes the most advanced and dependable integrated drive system available today.
    The D1 makes a continuous 60kW and 75kW peak power and over 1000Nm drive torque in a package weighing less than 150lbs, making it an ideal solution for small commuter vehicles and light duty trucks or utility vehicles. The D1 is designed to accommodate either front or rear wheel drive vehicles.
    A complete line of even more powerful and innovative D1g1tal Dr1ves are being designed and tested; further announcements to follow.
    Additional information including pictures and press kit can be found at www.d1g1taldr1ve.com.
    About MotoCzysz, LLC.
    MotoCzysz is a design and engineering firm that has been awarded numerous patents and now focuses primarily on electric drive systems and electric vehicles. MotoCzysz recently utilized the D1g1tal Dr1ve in the MotoCzysz E1pc experimental electric motorcycle and won the two largest and most important electric races in 2010: Isle of Man TT zero, IOM and the e-Power Red Bull MotoGP, Laguna Seca. MotoCzysz is also working with Indian Automotive and Motorcycle giant Bajaj on a bold solution for a next generation electric car. For more information contact Ryan Taylor MotoCzysz GM at ryan.taylor@motoczysz.com.
    - Mike
    2,647
    wow, nice.
    2,240
    Ooooh! Pretty!! But really, a digital display? What kind of dumb idea is that?
    2,240
    Does have a USB slot though, so at least I can plug in my iPod and listen to my favorite music.
    Canberra, Australia
    Ok so this requires 320Volts to drive.. so we are talking 100 cells in serial, and they need to be able to dump 200 - 300 amps...
    I now want to know about their battery packs!!!
    2,240
    364V from the specs. Not sure what the 320 on the display is supposed to be indicating. Days until Christmas? (Assuming that it's not a recent photo of course.)
    Canberra, Australia
    From this page... http://www.d1g1taldr1ve.com/d1-tech-specs/ it says... Operating Voltage (VDC nom.) 320 VDC nom. Assume it can vary around that due to pack voltage sag and charge state.
    even so I just priced a 200AH pack for this (thunderskys) in Aussie dollars it is around $32,000 Making the complete thing over $40,000 before chargers, BMS or anything else...
    Probably a good price for racing gear but expensive for the street.
    2,647
    but 75kw is the peak power. So at lets say 320V nominal, that would be 235A peak from the batteries. You don't need 200Ah batteries. You could use 80-100Ah worth of batteries at 2-3C and get that power. 200Ah of TS would be overkill, as 2-3C would be 4-600A. It would extend the life of the batteries by using less C discharge though. Hell, you could do that with 100s2p of 10Ah headway cells. for a 320V 20Ah pack.
    I find it awesome that they can get the price BELOW $9k, thats a gamechanger.
    Senior Member chdfarl's Avatar
    Dartmouth Ma.
    179
    Whats the cost of a battery pack like that. One kidney or two. Oh no the other kidney was to buy the D1g1tal Dr1ve. Oh well back to the drawing board. At least ICE chassis with blown engines are cheap!
    2,647
    for a battery pack that would put out 75kw, it would cost about $3500 or less. The digitaldrive is under $9k
