Likes Likes:  6
Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 121 to 130 of 137
Thread: Elmoto v2.0 Data sheet
  1. #121
    Moderator
    Isle of Man
    365
    Noah's got a copy on his site ... http://www.colorado.edu/physics/Educ...Elmoto2.18.xls
    Rob
  2. #122
    teddillard
    Guest
    The Google Docs version is still available: https://docs.google.com/spreadsheet/...hOUd3bVE#gid=0
  3. #123
    Mar 2012
    18
    Thanks guys! I was able to get it through the Google Docs version. Now its time to do some 'cypherin!
  4. #124
    Senior Member Hugues's Avatar
    Switzerland
    1,089
    Hi guys,
    i've been playing around with the sheet for a while,
    there is one thing i do not understand,
    in column I we can enter user defined inputs for motor torque
    but then in column F you see other figures for torque, which are lower than the one we enter,
    the graph on the right is showing torque from column F
    Why 2 columns with different values ?
    I want to simulate with the AC-20 motor and should enter 70 lbs-ft from 0 to about 4000 rpm (@96V),
    how can i do this ?
    thanks for explaining this part of the sheet, because acceleration data does not match the EV_Super_estimator sheet i found elsewhere on the forum,
    would like to understand what I'm doing wrong,
    thanks
    Regards from Switzerland
    My 2.5 Upgrade Thread
  5. #125
    Senior Member Coninsan's Avatar
    Sep 2010
    Kolding, Denmark
    414
    Sorry for the downed link guys, havn't been at my PC for some time so couldn't re-upload the sheet.. heh..
    The link in post 1 is now fixed
    And here it is for plain good measure. https://rapidshare.com/files/354519125/Elmoto2.18.xls
    Hi Hugeus
    The reduced Lb-ft is a result of your battery setup. Try incresing the Continuous Discharge entry and see the chart.
    This feature was added to let the user graphically know when and if the batteries was a constricting factor in his or her setup or if the motor was oversized.
    This being if the user intends on setting the controller current limit to match the recommended max CD of the battery pack. More drain than that would just be plain bad..
    "I reject your reality and substitute my own." Adam Savage
  6. #126
    Switzerland
    1,089
    Quote Originally Posted by Coninsan View Post
    Hi Hugeus
    Thanks, it's working now,
  7. #127
    teddillard
    Guest
    This seems to be AWOL again... anybody?
  8. #128
    Senior Member protomech's Avatar
    May 2011
    Nashville, TN
    215
    2006 Suzuki GS500, sold
    2012 Zero S ZF9
    http://protomech.wordpress.com/
  9. #129
    teddillard
    Guest
    Weird, that works but Rob's link above didn't for me... thanks!
  10. #130
    Moderator
    Isle of Man
    365
    Hmm, weird indeed. The URL was truncated. Edited now so both should work
    Rob
