Hi Flo,
did you find this:
https://fasterbikes.eu/de/zubehoer/g...t-ganzem-griff
Gruß
Kimi
Gesendet von meinem FP3 mit Tapatalk
Printable View
Hi Flo,
did you find this:
Gruß
Kimi
Hi Kimi,
yes i already found them - but i actually try to find the hall effect throttle tomaselli is selling.
Guess i just have to order that one, its a good and trusted product so can`t go wrong with it.
Thanks anyway.
Flo
The Gates company (and others, now that their patent is off) have a line of Poly Chain Carbon belts and sprockets that are much narrower than the older timing belts for the same power transmission. Older Zero bikes(maybe newer ones?) used a final drive belt that was only 14mm wide.
They are still expensive. What I usually do is set-up the drive with the cheaper (metal) chain drive to find the best ratio, then switch to the much nicer to work with and run belt drive closest to that ratio.
I'm interested in converting.... but you're using a jackshaft, right? Do you have any links with prices that we can check out? Thanks
Sent from my Pixel 3 using Tapatalk
The 14mm wide Gates belt on my 2012 and 2014 Zero S cost $80 one year and then went up to $120 a couple of years later. I bought a spare 17mm wide Gates belt for my 2018 Zero S two years ago and that cost $140 from my Zero dealer. The discontinued BMW F800GT uses a much wider belt and the word is that will set you back $450, plus another $200 for installation. :O I think I heard that it is not a Gates belt but a Continental-brand item.
Hi,
yes that is all good and valid for your normal drive set up.
Using the belt calculator of Mädler.de i found that once you are using smaller sprockets overall and having higher revs on the belt itself , then the calculator gives you much lower values per width.
So if your motor turns say 5000 and you have 5`: 1 gearing , first off your belt has less speed and the torque is transmitted via a much bigger gear to your wheel (force times lever). That is completely different to a say 1: 1,5 gearing where the belt would still rev with 4000 rpm itself on a small set of gears...
Greets
Flo
It would be interesting for you to run through the calculations you have used to figure this out.
well i haven`t gone through the calculations myself. But what i did is to run umpteen scenarios through the Beltcalculator on the mfg`s site. www.mädler.de for those interested. This of course only shows their product but other sources didn`t show any data at all.
Maybe the aforementioned belts being different or stronger or whatnot but without confirmation i personally wont use them, Appart from the fact that i now already have bought all chain setup and milled up all parts.
Its always good though to throw in new ideas.. so maybe next time :)
Greets
Flo
Belts would be awesome for maintenance freedom and reduce weight, but only if they are stronger than a chain.
I'm wondering if some company is creating a graphene carbon belt in the works.
Thank you for the belt/sprocket supplier reference. In a rough, quick comparison it appears the Gates Poly Chain GT Carbon belt/sprocket system(and its new clones?) has 1.5-2 X the power transmission capacity of the systems you referenced. These would be, from what I could see, the traditional trapezoidal tooth and the lighter duty HTD systems. If your roller chain system does not work out, flings too much oil, gets really noisy, and turns blue from the heat(I've seen this happen!) try this Gates system. It can be quite noisy in some drives and need a sound cover; and quite expensive.
For the novice, to find the Gates parts, it's probably best to go through a supplier like flo has done.
