Results 1 to 10 of 11
Thread: LED headlights?
    Detroit, MI.
    276
    LED headlights?
    We have talked about LED headlights on here before. The issue seems to be that here is no/few DOT approved LED headlights. I saw this, and thaught I would pass it along:
    Harley Davidson LED headlight
    It IS, however, stupid expensive @ nearly $400!
    899
    These 7" lamps are available from several sources
    http://www.customdynamics.com/high_i...d_headlamp.htm
    3,889
    Those say 4.5A for high beam, 2.5A for low. That seems like a lot, it's about the same as regular incandescent bulbs.
    I run an LED replacement bulb for my low beam during the day. It was about $9 on ebay, drop in replacement. Not DOT, but I've never had a problem. I run my regular high beam at night.
    Canberra, Australia
    J. W. Speaker make DOT approved headlights (even more expensive than above) http://www.jwspeaker.com/other/led-headlamps that draw 2.5 amps (12 volts) for each beam. I have been thinking about it but not yet bit the bullet.
    3,889
    If these LED headlights are 2.5A, then don't do it for the energy savings. A typical halogen bulb is 60W, which is 5A on the 12V system. But if you're running 72V, it's only drawing 0.83A from the pack. If you go with a 2.5A LED light, you save a whopping 0.4A.
    I put in an LED low beam, but mostly for the looks.
    Canberra, Australia
    Ok I said 12 v as most use aux power for headlight, indicators etc. JW speaker ones work at 12v and 24 volt and use less current (1.3) at 24 volts. They have a led driver circuit in them and will handle a range of input voltage (not sure total range) and the current use drops and voltage increases. Some of the lights I linked to (if you go to more info) use 1 amp (12 volt) for low and 2 amp (12 volt) for high. So they would be using about half the power of halogens.
    These guys tend to sell more lights to emergency service vehicles not for the saving of power but for longevity of the lights especially when they are flashing most of the time....
    3,889
    True, longevity is nice (although the $9 ones I got were Chinese ebay specials...so who knows).
    Mar 2011
    Oklahoma City, Oklahoma
    1,812
    dont worry fellows - i work for a sign company and there was a time when we wouldnt even considered using LED's compared to incadescent bulbs and neon lighting for our applications - but sales reps are coming out with brighter and cheaper lighting solutions constantly - neon lit channel letters and cabinets using light bulbs are a thing of the past here. some of the LED lights we use are extremely bright and affordable... these are the products we use...
    http://www.sloanled.com/Channelletter_SignCab.html
    May 2012
    we been using LEDs led strip lights to light our signs we produce for several years now - the LED's have become very impressive... flexible led strip
    right now at this moment - GE is producing the brightest LED... LED Light Bars
    all of the newer Hobby Lobby stores that we build signs for are all LED...
    Apr 2012
    77
    Aaagh...my Zero's headlamp nacelle doesn't accept full round headlamps like the links show (and that's all I've seen). I need to do something about it, because the light on it is wimpy compared to the 3-light setup on my Road King (and what's with the double-wimpy little flashlight bulb above it?). It looks like my best bet for a drop-in replacement is a HID retrofit kit, as it's essentially just a bulb replacement inside the housing (with the electronics mounting externally).
