Likes Likes:  66
Page 30 of 30 FirstFirst ... 20282930
Results 291 to 299 of 299
Thread: e-Cruiser version 1.0 build thread
  1. #291
    Sep 2013
    Australia
    205
    The quality is so high on your bike that I don't think there would be any issues, and if there is it would be a minor technical issue. Like splinter had to engrave a warning on the brake reservoir cap to say "Only Use DOT4 fluid".
    Your engineer would have pointed out any issues before you booked your appointment.
    Sent from my HTC Sensation using Tapatalk
  2. Likes ElMotoMike liked this post
  3. #292
    1,089
    Nice sunny day today, getting the bike ready for tomorrow's inspection, 15h00.
  4. Likes Skeezmour liked this post
  5. #293
    1,089
    Update 17.3: as someone was saying earlier 90% done, 50% to go !
    I brought the bike to the registration office today, they were pretty impressed, lots of people showed up, lots of questions and pictures.
    But, there is a but, I did not get my license plate today
    They listed a few little safety things to correct:
    - switch on the kickstand to prevent the bike from running if the kickstand is out
    - little blue LED when on high beam
    - my mirror was too small, need to be at least 50 cm2
    - my back flashers are not visible enough, need to make them slightly longer
    - my front beam is from Harley D, it does not have a position LED as required in Europe, bike shop gave me the replacement LED
    WHen all this is corrected (i'll do the mods myself), i need to show them and i should receive my license plate.
    That shouldn't take long I guess.
  6. #294
    Canberra, Australia
    Nothing huge then but irritating. Switch on the kickstand can be painful to setup depending on how it all bolts together there.
    SplinterOz
    From Australia'a Capital
  7. #295
    Senior Member Athlon's Avatar
    Jul 2011
    Milan, Italy
    Add Athlon on Linkedin
    This sound the right job for the interlock
  8. #296
    1,089
    Finally gotr my license plate !
    Woooooouuuuuuu oooouuuu !
    Finally got my license plate this week, after more than 2 years of work, cooooooooooooollllll !
    Thanks to the whole elmoto gang for all your help and patience during all that time !
    I will now stop this build thread here and start a new "ride thread"
  9. Likes markcycle, Nuts & Volts, Skeezmour liked this post
  10. #297
    3,889
    Hugues, I just read this post over on the Moto Guzzi thread. Wanted to ask here so I don't divert that thread.
    You said "I still need to improve my bottom balancing."
    Are you sure you mean bottom balancing? The Orion top balances, so it will eventually top balance your pack. It should just be top balanced from the start.
  11. Likes Athlon liked this post
  12. #298
    1,089
    I'm actually experimenting with bottom balancing, just want to see for myself.
    So I "switched-off" top balancing on the Orion BMS by setting the "start balancing voltage " at 3.65. So it never gets to balancing.
    I monitor discharge with a LVC signal from BMS to controller and charge with a HVC signal to charger, while keeping an eye on highest cell voltage, just in case
    We'll see where this brings me.
  13. #299
    3,889
    Makes sense. Have fun!
