Results 1 to 9 of 9
Thread: Motor alignment
    Senior Member moon's Avatar
    Dec 2010
    Fort Collins, CO
    192
    Motor alignment
    What's the most effective, precise way to verify good alignment of the output shaft to the rear axle/sprocket?
    My search-fu is weak today.
    I used angle iron. Lined it up to the rear sprocket.
    Sent from my SAMSUNG-SGH-I997 using Tapatalk
    EVangelist electriKAT's Avatar
    DC
    416
    Someone on this board advised me when I did mine (EVcycle, or ZoomSmith?). It is a simple, but effective method.
    First, install your motor mount plate without the motor. Insert a long piece of allthread through one of the holes in the plate so the allthread is parallel to the rear axle. Use washers and nuts on either side of the plate to lock the allthread in place. Now measure the distance from the allthread to the rear axle on each side of the bike. Adjust the motor mount plate until the distance on each side is equal. You will also want to use a level on the motor mount plate to make sure the plate is vertical. Once you've got all of your spacers figured out to get the proper alignment, remove the plate, install the motor, and then reinstall everything using the spacers.
    Another neat trick is for aligning the drive sprocket with the rear sprocket. Let me know if you want me to write that up. It's a little hard to explain without pictures.
    Member CharlesZaden's Avatar
    Jun 2011
    Austin, Texas
    64
    Thank you for this tread Moon
    yes please!
    perhaps we should just have a general "Tips and Tricks" thread... hmm...
    - Chris [1982 Honda EV650]
    "Just throwing science at the wall and seeing what sticks"
    Moderator ZoomSmith's Avatar
    Walla Walla, WA
    775
    someone on this board advised me when I did mine (EVcycle, or ZoomSmith?). It is a simple, but effective method.
    I think that was WWC (http://www.evalbum.com/2003).
    I used a machinists square on the swingarm pivot. You have to be careful referencing the rear axle since it's not fixed.
    DC
    416
    Front Sprocket Alignment
    Maybe sticky this thread?
    OK, here goes. This is the best picture I could come up with on the spot. Perform this procedure *WITHOUT* the chain.
    Tie a string around the rear wheel.
    Run the string across the rear wheel sprocket up to the drive sprocket.
    Pull it tight so that it contacts the rear edge of the rear wheel sprocket.
    Adjust the horizontal placement of the drive sprocket on the motor shaft so that the string will touch the outside edge of the drive sprocket and the leading edge of the rear wheel sprocket at the same time.
    Lock the drive sprocket in place.
    DC
    416
    Quote Originally Posted by ZoomSmith View Post
    I think that was WWC.
    That link doesn't look familiar. It must have been Ed (EVcycle).
    Your rear axle had better be fixed before you try to ride or you're in for a heap o' trouble
    I understand what you're getting at, but if I can assume you've got the rear wheel square in the swing arm, this method will align your motor mount plate square with the rear axle. And that's what you're trying to do. Not to say your method won't work just as well.
    Dec 2010
    Fort Collins, CO
    192
    These are some great tips, thanks! I tried the allthread method and it worked great, when I get sprockets I will try out that method as well.
    Good posts!
    1,956
    Not sure it was me either..... All of us help everyone we can....
