Results 1 to 6 of 6
Thread: Turnsignals
    Aaron Lephart
    Turnsignals
    Aside from hitting them off the fender every now and then, does anyone have a problem with the bulb coming out of its socket base?
    It has happened more then once now for me. I thought about tring to "bend" the clips in that hold the bulb in place.
    Like the taillight I believe these lights are a OEM sourced solution.
    I am not a fan of using "wedge base" bulbs on applications that see alot of vibration!
    All the best,
    Aaron Lephart
    1,962
    Try tie wrapping them in place?
    I had to do that on old Triumph's .
    Aaron Lephart
    The actual bulb?
    All the best,
    Aaron Lephart
    1,962
    Yes, Got a photo of the bulb?
    Aaron Lephart
    Horrible photo, quickly taken with cell phone:
    All the best,
    Aaron Lephart
    1,962
    OK, That type. Mmmmmmmmmm
    Not sure what to do unless you can change just the socket to the twist and lock style.
