Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Water cooling a 2013 Zero Motor
    Senior Member Athlon's Avatar
    Jul 2011
    Milan, Italy
    Add Athlon on Linkedin
    Quote Originally Posted by liveforphysics View Post
    In the hubmotor applications, the oil level gets filled to about 1-2" below the axle bearing. This eliminates the need for a special bearing seal (just RTV sealing the side plates). It works wonders, easily 2x continuous power in exchange for ~1-2amp higher no-load.
    I was thinking soe time ago to do the same to my E-max scooter ( http://www.greencarsite.co.uk/GREENC...-max-moped.jpg ) but later I thinked about the oil cooling only the lower part of the stator and not the top part so I didn't make any modification to my scooter , how effective is the cooling on the top part of the motor ? Did you tryed to put multiple temperature sensor inside the hubmotor.
    Back to the Zero motor .. anyone have a picture of the inside of the motor just to see if the roto is smooth or not, smoother rotor will work better with oil.
    Feb 2011
    520
    Rotor surface is smooth.
    Feb 2011
    Calgary, Canada
    78
    the surface is smooth, but the rotor has spokes from the shaft to the surface, so cavitation will be a big issue if you put too much oil in.
    1,089
    Quote Originally Posted by Biff View Post
    Has cavitation been demonstrated in such a setting and with oil ? at around which rpm ?
    that could be nasty.
    compared with water though, i presume oil is less likely to produce cavitation ? due to higher boiling point ? or is it related to viscosity too ?
    i could google it you might say...
