Results 1 to 10 of 16
Thread: Wrap electrical wires in tin/aluminum foil may increase voltage/current -- Youtube
    137
    Please TRY this with a multimeter and a constant voltage source, with a baseline (no alumimum wrap on wires) and then with the tinfoil wrap on the wires. Please video your experiment and post it on any video server. It seems wacky, but I have seen a experimenter s video clip with unexpected results --- the voltage became increasingly higher as more wires were wrapped. I'll post that clip here as soon as I can figure out how to do it.
    In the meantime..
    Please try to replicate this Alumimium Foil gas improvement trick on your car, and post your results on this forum, so we can all know, if this works or not. 100MPG Sentra in Philippines.
    YouTube - 100 MPG Car - Nissan Sentra - Pinoy Experiment
    YouTube - 100MPG Car - Nissan Sentra - Pinoy experiment - Sequel 2
    John Williams - Main Theme from Star Wars (Instrumental)
    www.youtube.com/watch?v=fVtLm-MzIzs
    100 MPG Car - Nissan Sentra - Pinoy Experiment - Video
    This video presentation is about Mr. X's 100MPG Nissan Sentra... as a matter of fact, it's more than 100 MPG. The car is a 1999 Nissan Sentra LEC GA13. Watch Video about 100MPG,Nissan,Sentra by Metacafe.com
    http://www.metacafe.com/watch/yt-Jzr..._nissan_sentra..
    The Nissan Sentra And Its Safety Featuresd ...
    This video presentation is about Mr X s 100MPG Nissan Sentra as a matter of fact it s more than 100 MPG ... To play all click http www youtube com watch v b74naeawdCs ...
    http://www.salernoblog.com/2010/03/0...and-its-safety..
    Nissan's surprising Sentra - Worldnews.com
    100 MPG Car - Nissan Sentra - Pinoy Experiment ... Eric Clapton's "Change the world" for the background music... but youtube ...
    article.wn.com/view/2010/06/30/Nissans_surprising_Sentra
    137
    Shiny side of the aluminum foil should be on the outside of the wires??
    http://www.freerepublic.com/focus/f-news/578853/posts
    A Note About The Shiny Side:
    It can't be stressed enough how important it is to have the shiny side pointing out. This is needed because the shiny side is most reflective to psychotronic radiation, while the dull side can actually, in certain environmental conditions, absorb it. However, as is illustrated in the instructions above, it is also wise to complement this with a layer of foil pointing shiny side in. This will keep your brain waves, which are also reflected by the shiny side, from being picked up by mind-reading equipment. There is a small number of aluminum foil researchers who believe that this may cause an alpha-wave harmonic to build up in the skull resulting in memory loss or pseudo-religious visions, but their findings have never been replicated by the aluminum foil research community at large. Even if their findings are validated, the risk involved is small compared to the potential of mind-intrusion.
    Senior Member billmi's Avatar
    Palm Bay, FL
    762
    Those guys in the Philipenes can make this work, but it won't work here in the states.
    The reason is that the South Pacific is centered under a vortex of the Van Allen Radiation Belts. They are innundated by psychotronic radiation. In places where the re is no psychotronic radiation, it's not a problem, so shielding against it doesn't have a benefit.
    :-P
    this explains so much, really.
    is this guy for real?
    why yes. for real. painfully so. a small sample of the TRUTH from the sites linked:
    "FOOL! KNAVE! IDIOT! THE FIT OF THE HAT MAKES IT WORSE THAN USELESS!!!!! UNLESS YOU HAVE COMPLETE SKUll COVERAGE, THE TINFiOL WILL SERVE TO FOCUS YOUR THOUGHTS FOR THE MIND-CONTROLLERS. !!!!!!
    HE,LPMEIAMThinAKAIUNG THe voiCEzIMMYHEADSARELERARNIUNAQG TO TYPEing!! "
    ...disregard at your own peril.
    (edit. omgomg, this is the most hilarious thread I've read in ages: http://www.freerepublic.com/focus/f-news/578853/posts#3 )
    Moderator ZoomSmith's Avatar
    Walla Walla, WA
    775
    Why would we waste any time experimenting on ICE's?
    I wore a tinfoil hat at the last Kickball game I went to..... and then it started pouring rain. The only benefit was, that it kept my hair COMPLETELY, unlike the rest of my team.
    electrician
    The best use for tin foil is in the kitchen.
    It doesn't make sense to wrap your wires in it to gain anything, except a possibility of a short from loose tin foil.
    However, if you want to use it for hat that seems safe enough, lol.
    137
    Quote Originally Posted by ZoomSmith View Post
    You should try it on your elmoto, not the ICE, and see if there is a difference from a baseline. Please post your video results, like Jack Rickard does.
    For the poster who states that it only works in the tropical zone, be advised that one or more videos exist that show an unexplained voltage increase in North America, too.
    Shouldn't we just all do experiments, like Jack --- or is this just a yakity yak forum?
    For those who are going to try this on an ICE, here is more tin foil wrap postings snipped ..
    Found this on a fuel economy site. Wonder if it has has any merit???
    Cover Oxygen Sensors with Aluminum Foil: Wrap your oxygen sensors in the exhaust pipe with 7 to 10 layers of shiny foil.
    Advantage: The car computer system depends on the oxygen sensors to adjust the air-fuel mixture being fed to the engine. The cooler the exhaust gases, more fuel gets sent to the engine. The hotter the exhaust gases, less fuel will be sent to the engine.
    Directions: To seal maximum warmth inside the exhaust pipe, insulation in the form of Reynolds Aluminum Foil is employed to insulate the oxygen sensor. Wrap five inches in front and five inches after the sensor to keep it much warmer. We double a one-foot section of foil and wrap that around the pipe and around the sensor itself. Do not remove the sensor. Then we repeat the process four more times. Finally we use .030" copper or aluminum wire to wind around the aluminum foil to keep it from blowing away and be sealed against water. The wire comes from any welding supply. The goal is to fool the car's computer into sensing too rich a mixture so it adjusts with a slightly leaner mixture and possibly a slight advance in timing. The end result is smoother engine operation and better MPG. This trick is especially important in severe winter climates.
    I have tried this one and normal rules are if an oxygen sensor gets hotter it is lean and tells the computer to richen, but the oxygen sensor doesnt work unless temperatures are above 600deg in the exsaust which i found out on a site so the computer if it doesnt get a response from the oxygen sensor automaticly richens the mixture.
    I found this hard to believe but have tried it and since the engine is 20% quiter and alittle bit more efficent.
